What prevents mass-less gauge bosons and gravity going faster than c?
In summary, the limitation of the speed of mass-less gauge bosons and gravity to the speed of light, c, is a fundamental property of the universe that is consistent with the theories of Special and General Relativity and Lorentz Invariance. This speed limit is not caused by any known phenomenon and has likely existed since the beginning of the universe. It is a fundamental property, similar to other properties possessed by elementary particles, and may remain the ultimate speed limit unless new discoveries are made.
Bararontok
298
Whether traveling at c in the form of radiation and carrying energy in the process or to exert the force propagated by force fields, the mass-less gauge bosons cannot go faster than c and even the gravitational force which is caused by the space-time curvature or hypothetically gravitons cannot go faster than c. What phenomenon is imposing this limit on the mass-less gauge bosons and gravity?
Special relativity.
Why should mass-less gauge bosons and gravity go faster than c? ;)
With more and more energy being added to the system propagating as radiation or force, should the extra energy not propel all of these radiation and fields faster and faster and faster unless there is something to stop it? After all, mass is what limits fermions from going faster than c, so what is imposing a limit on the mass-less particles and gravity?
The speed of those bosons does not depend on their energy - that is a direct consequence of special relativity.
Mass and the laws of relativity limit massive particles (not just fermions) to speeds below c, and the same laws force massless particles to have a speed of c.
But what about gravity, since it is the source of relativistic phenomenon, why is it limiting itself to c?
Is it because, in space there is no absolute vacuum because of the presence of radiation and force fields and anything traveling through space has to interact with the other objects such as the space-time curvature and even when the interaction is weak because the object is distant from the source of the force, this interaction forces the limit of c onto the object, even if it is mass-less.
Read an introduction about (special) relativity, please. I cannot and do not want to replace a textbook.
While I agree with MFB, it can also be said that there is simply a maximum speed limit that changes within the universe can propagate at. This limit is the velocity c. Massless particles happen to travel at c because they are massless. To my knowledge there is no known underlying reason for there to be a maximum speed limit, we only know that there is. Although if there wasn't, things would be much different in the universe.
Likes 1 person
Yes that is true, while I understand that the limit of c is shown to be mathematically consistent with the theories of Special and General Relativity and Lorentz Invariance and that going faster than c would violate causality, what I was looking for was not the mathematical and verbal description of the phenomenon but what causes the limit or how it originated. Perhaps, just like the other fundamental properties that the elementary particles and the curvature of space-time possess, this speed limit of c for mass-less particles does not have a cause and is simply a fundamental property that has no known origin and has existed for eternity, just like how energy cannot be created or destroyed and instead only changes form. Additionally, just like the other fundamental properties that make each elementary particle unique, the speed limit of c is just another property that simply exists. Although it may be possible that c is not really the limit if in the future a particle is discovered that can move faster than c. In conclusion these fundamental properties and physical constants are the final cause and basic building components of everything in the universe unless even more fundamental properties and phenomena are discovered. This question has been answered, thank you very much.
Related to What prevents mass-less gauge bosons and gravity going faster than c?
1) What are mass-less gauge bosons and gravity?
Mass-less gauge bosons and gravity are both types of particles in the Standard Model of particle physics. Mass-less gauge bosons are fundamental particles that carry forces, such as photons for electromagnetism and gluons for the strong nuclear force. Gravity is a force that is responsible for the attraction between masses.
2) Why can't mass-less gauge bosons and gravity travel faster than the speed of light?
According to Einstein's theory of relativity, the speed of light is the maximum speed that any particle or information can travel in the universe. This applies to all types of particles, including mass-less gauge bosons and gravity. Going faster than the speed of light would violate the laws of physics and lead to paradoxes.
3) What prevents mass-less gauge bosons and gravity from going faster than c?
The main reason that mass-less gauge bosons and gravity cannot go faster than the speed of light is because they have zero rest mass. According to the equation E=mc^2, particles with zero mass would require an infinite amount of energy to reach the speed of light. Since it is impossible to have an infinite amount of energy, these particles are restricted to traveling at or below the speed of light.
4) Are there any exceptions to the rule that mass-less gauge bosons and gravity cannot exceed the speed of light?
There are currently no known exceptions to this rule. However, some theories, such as string theory, propose the existence of extra dimensions that could potentially allow for particles to move faster than the speed of light. However, these theories are still highly speculative and have not been proven.
5) How is the speed of light related to the behavior of mass-less gauge bosons and gravity?
The speed of light is a fundamental constant in the universe that dictates the behavior of all particles, including mass-less gauge bosons and gravity. The theory of special relativity, which includes the speed of light as a constant, explains how energy, mass, and velocity are all interconnected. The speed of light plays a crucial role in shaping the laws of physics and determining the behavior of particles in the universe.
  • Beyond the Standard Models
  • STEM Academic Advising
