What properties of waves causes the photoelectric effect
In summary, the photoelectric effect suggests that the energy of electrons is quantized due to the specific wavelengths of light that are absorbed. This indicates that light is not a continuous wave, but rather consists of discrete packets of energy. If electron energies were not quantized, there would be a continuous spectrum of absorbed wavelengths rather than a limited number.
Photolicktrick
What properties of waves caused the photoelectric effect to indicate the fact that light was quantized. Why couldn't it be explained by light waves being emitted at the same frequency. I am a little confused about why light couldn't still be a wave. Couldn't the photoelectric effect be explained because many light waves of the same frequency and thus the same energy be responsible for the fact that electrons only get exited by light of a certain energy. I just don't understand what quantization has to do with it.
The photoelectric effect is the dominant mechanism for low energy light wavelengths impacting high atomic number elements. It hints at electron energies being quantized, because only certain wavelengths of light are absorbed by the material and their energy is converted into the electrons' kinetic energy. If electron energies were a spectrum rather than being quantized, there would be a continuous spectrum of wavelengths of light being absorbed rather than a finite number of wavelengths.
Related to What properties of waves causes the photoelectric effect
What is the photoelectric effect?
The photoelectric effect is the phenomenon where electrons are emitted from a metal surface when light of a certain frequency shines on it.
What are the properties of waves that cause the photoelectric effect?
The properties of waves that cause the photoelectric effect are the frequency and intensity of the light, as well as the energy and momentum of the photons.
How does the frequency of light affect the photoelectric effect?
The frequency of light is directly related to the energy of the photons. The higher the frequency, the higher the energy of the photons, and therefore the more likely they are to cause the emission of electrons from a metal surface.
What is the threshold frequency in the photoelectric effect?
The threshold frequency is the minimum frequency of light required to cause the photoelectric effect. Below this frequency, no electrons will be emitted, regardless of the intensity of the light.
Why do different metals have different thresholds for the photoelectric effect?
The threshold frequency for the photoelectric effect varies from metal to metal because it is dependent on the binding energy of the electrons in the metal. Different metals have different electron configurations and therefore different binding energies, resulting in different threshold frequencies.
  • Electromagnetism
