What remains after H2O evaporates from H2SO4?
  • Thread starter maker
In summary, the conversation discusses a 5 gallon container that was filled with a 15% H2SO4 solution and an aluminum rod. After sitting for several months, all of the water has evaporated and a portion of the aluminum has corroded, leaving behind white crystal powder. The substance is likely aluminum sulfate and the best method of disposal is dilution or using it as a soil amendment. The conversation also touches on the properties and dangers of concentrated sulfuric acid.
maker
Hi,
I have a 5 gallon container that was 1/2 filled with an H2SO4 solution (15% by volume). The solution also had 6051 aluminum rod that was sitting inside.
After sitting for several months, all of the water has evaporated (or reacted?) and a portion of the aluminum tubing has corroded away. What is left is white crystal powder attached to the remaining aluminum.
Can someone tell me what this substance is? I'm guessing it is salt crystals attached to aluminum rod, but I'm no chemist! Assuming this is something other than salt, what is the best method of disposal (i.e. Bring it to hazardous waste disposal, dilute and flush, poor it in my garden :) , pour it in my neighbors garden :D)?
My Ph meter is broken, so I can't even check the Ph at the moment.
Thanks,
M
Chemistry news on Phys.org
It's likely that it produced aluminum sulfate. You can google it. It is sometimes used to lower the pH of soil and apparently is also sometimes used to melt ice and snow on sidewalks.
Likes jim mcnamara
Water doesn't evaporate from a ##H_2 SO_4## solution of that strength, because the sulfuric acid is hygroscopic. Instead, it absorbs water vapor from the air and becomes more dilute. ##H_2 SO_4## reacts with aluminum to produce hydrogen gas and aluminum sulfate/bisulfate or complexes of those salts with ##H_2 O## and ##OH^-## species (except maybe if the acid is so concentrated that it acts as an oxidizer and produces a protective film on the metal). If you put aluminum and ##H_2 SO_4## in a sealed container, it is likely to explode because of the pressure of the hydrogen gas - don't do that. You probably had an open or loosely closed container in this case ?
It's Al2(SO4)3, AlH(SO4)2 and similar.
Neither aluminum nor SO4 ions are hazardous, or we wouldn't routinely use aluminium spoons and gypsum.
Per original question, if you 'dehydrate' an H2SO4 solution, you'll finish with SO3. It's hard energetically, as both SO3 and the increasingly concentrated H2SO4 are very, very hygroscopic.
FWIW, I used to work in an Analytical lab, remember noticing a 'serious stupid' in progress; "Hey ! Acid to water, not--"
Click !
The Pyrex litre measuring cylinder had cracked at the interface between the 900 mls of 'Conc Sulf' and the slosh of water. The crack spiralled down the cylinder's length. For a cartoon-instant, the mortally wounded cylinder just stood there. Then, it twisted open, emptying its contents over the bench. The operator jumped back. I jumped *sideways*, went for the acid-spill kit...
{Shudder...}
Likes Asymptotic
Related to What remains after H2O evaporates from H2SO4?
1. What is the chemical formula for H2SO4?
The chemical formula for H2SO4 is sulfuric acid.
2. Does anything remain after H2O evaporates from H2SO4?
Yes, after H2O evaporates from H2SO4, the remaining substance is sulfuric acid.
3. Is it safe to inhale the fumes of evaporated H2SO4?
No, it is not safe to inhale the fumes of evaporated H2SO4. Sulfuric acid can cause irritation and damage to the respiratory system.
4. What are the properties of sulfuric acid?
Sulfuric acid is a strong mineral acid that is highly corrosive and can cause burns. It is also a dehydrating agent and can react with many substances, causing chemical reactions.
5. How is sulfuric acid commonly used in industries?
Sulfuric acid is used in various industries as a key component in the production of fertilizer, chemicals, and explosives. It is also commonly used in the production of batteries and as a cleaning agent for metals.
17K
46K
25K
