What size do particles start to get a quantum effect
In summary, the transition between classical physics and quantum physics is not clearly defined based on size. However, it is generally accepted that individual particles, atoms, and molecules require a quantum description while large systems of these objects can be described by classical physics. Additionally, there are macroscopic systems, such as bose-einstein condensates, that show genuine quantum behavior. The exact size at which quantum effects start to dominate is still debated, with some experiments showing effects at 430 atoms. Ultimately, the presence of quantum effects at all scales means that the distinction between classical and quantum physics is subjective and based on individual interests.
Dammes
Im wondering at what size particles/object start to get a quantum effect? At what size does classical physics stop and at what size does quantum physics start?
Well, as far as I understand we typically talk about quantum effects starting to dominate around the small-medium molecule scales. However, this really depends on what you are trying to figure out or discuss. The difference between two electron states in a large polymer probably requires quantum mechanics, but that polymers behavior in a material may or may not.
Personally I would say that individual particles, atoms, and molecules generally require a quantum description, while large systems of these objects can be described by classical physics in most situations we deal with. I just don't think it's a clear cut between the two.
when hbar starts looking a little less non-zero
or more accurately speaking when the derivative of the de brodglie wavelength with respect to the coordinates stops being << 1
There are even macroscopic systems which show genuine quantum behavior like bose-einstein condensates, superconductors, superfluids, ...; even a single pair of entangled particles shows quantum behavior. There is no absolute size in terms of length scales or number of particles
it is believed that over 1014 atoms begins macrorealism.quantum mechanics effects, actual experimental limit, 430 atoms:
http://www.nature.com/ncomms/journal/v2/n4/full/ncomms1263.html
...PFNS10 and TPPF152 contain 430 atoms covalently bound in one single particle. This is ∼350% more than that in all previous experiments...
...in our experiment, the superposition consists of having all 430 atoms simultaneously 'in the left arm' and 'in the right arm' of our interferometer, that is, two possibilities that are macroscopically distinct. The path separation is about two orders of magnitude larger than the size of the molecules...
How long is a piece of string?
There are quantum mechanical effects at all scales. Whether they are large enough that you care about them is a statement about what you care about, not anything physical.
Thanks for all the replies, I understand know.
thanks
FAQ: What size do particles start to get a quantum effect
What is the minimum size for a particle to exhibit quantum effects?
The minimum size for a particle to exhibit quantum effects is typically around the size of an atom, which is approximately 0.1 nanometers. However, this can vary depending on the specific properties and behavior of the particle.
Can larger particles also exhibit quantum effects?
Yes, larger particles can also exhibit quantum effects. While the effects may not be as pronounced as they are in smaller particles, quantum mechanics still applies to particles of all sizes.
How do particles behave differently at the quantum level compared to the macroscopic level?
At the quantum level, particles behave in a probabilistic manner and can exist in multiple states or locations at the same time. This is known as superposition and is not observed in the macroscopic world.
Are there any particles that do not exhibit quantum effects?
All particles, regardless of their size or type, are subject to the laws of quantum mechanics. However, some particles may have properties or behaviors that are not fully understood or explained by current quantum theories.
Can the size at which quantum effects occur be manipulated or controlled?
There are ongoing scientific efforts to manipulate and control the size at which quantum effects occur. This could have potential applications in quantum computing and other advanced technologies.
