What size is the Global Stiffness Matrix in this Example?
The global stiffness matrix for a beam composed of three elements and four nodes, considering lateral deflections and slopes, is indeed an 8x8 matrix. This is calculated by multiplying the number of nodes by the degrees of freedom per node. In contrast, a beam with two elements and three nodes results in a 6x6 stiffness matrix. Many online resources lack clarity and straightforward explanations, often omitting essential details or mixing concepts. Understanding the calculation method is crucial for accurate stiffness matrix formulation.
ihebmtir
TL;DR
4 nodes global stifness matrix
does this Beam, composed of three elements and 4 nodes(considering lateral deflections and slopes) has an 8x8 global stifness matrix
and if so is the global matrix calculated the same way as a 6x6 stifness matrix for the same kind of beam but only with two elements and 3 nodes
The size of global stiffness matrix is the number of nodes multiplied by the number of degrees of freedom per node.
Arjan82 said:
There is tons of info on the web about this:
https://www.google.com/search?q=global+stiffness+matrix
Yes, all bad. I looked at many sources and none of them follow a straightforward problem without shortcuts that obscure the method or missing key details or not explaining where things go or mixing numbers and matrices or whatever.
Had my central air system checked when it sortta wasn't working. I guess I hadn't replaced the filter. Guy suggested I might want to get a UV filter accessory. He said it would "kill bugs and particulates". I know UV can kill the former, not sure how he thinks it's gonna murder the latter. Now I'm finding out there's more than one type of UV filter: one for the air flow and one for the coil. He was suggesting we might get one for the air flow, but now we'll have to change the bulb...
10K
15K
