What substance(not really a lube) can reduce friction signifigantly?
  • Thread starter harleyquin
  • Tags
    Friction
In summary: You could create a very smooth surface by using a rolling pin and plastic wrap. In summary, a lubricant may not work because it would come off all over the ground, a Teflon-coated shoe would have low friction, and a smooth surface can be created using a rolling pin and plastic wrap.
harleyquin
I need suggestions for a type of surface that you could be able to put on the bottom of your shoe and be able to slide easily. (Please, do not say wheels.) The catch is that you don't want it to scratch off and using a lubricant is most likely not going to work because it would come off all over the ground.
For example, imagine if you had a teflon coated shoe. You would be able to resist friction significantly and would be able to glide as if you did have wheels on your shoe. The only thing is it would more than likely come off after a few scrapes right?
So the question is, what is a surface that you could apply to the bottom of your shoe that would not come off and allows you to reduce friction enough to glide/slide easily?
P.S If you can think of a lubricant that wouldn't scrape off on the floor/pavement please add it!
thanks!
You've heard of brain storming, what you need is trystoming. Of course the better you slide the harder it will be to work.
First Robotics used sheets of some white plastic stuff from Home Depot as a low frictions surface a few years ago, go explore the wall panel section.
PTFE or PFA (Perfluoroalkoxy) would be my suggestion. You could make a sole out of solid Teflon and this would be pretty robust.
A brush with long bristles made of something smooth and hard-wearing. A jet of air through the bristles might give it even less friction.
Like sliding the dog around the floor while it clings to the broom head.
I didn't know that you were a fellow Canadian! That's "pond curling" in a nutshell.
Related to What substance(not really a lube) can reduce friction signifigantly?
1. What is the most effective substance for reducing friction?
The most effective substance for reducing friction is a lubricant. Lubricants are specifically designed to reduce friction between two surfaces and improve their sliding or rolling motion.
2. Can any substance be used as a lubricant?
No, not all substances can be used as a lubricant. Lubricants must have certain qualities such as low viscosity, high boiling point, and chemical stability in order to effectively reduce friction.
3. How does a lubricant reduce friction?
A lubricant forms a thin layer between two surfaces that helps to separate and reduce the contact between them. This reduces the amount of friction and wear on the surfaces, allowing for smoother movement.
4. Are there any natural substances that can reduce friction?
Yes, there are some natural substances that can reduce friction such as oils, fats, and waxes. These substances have been used for centuries as lubricants in various applications.
5. Is there a difference between synthetic and natural lubricants?
Yes, there are differences between synthetic and natural lubricants. Synthetic lubricants are man-made and have been specifically designed for certain applications, while natural lubricants are derived from natural sources and may not be as effective in some situations.
  • STEM Academic Advising
  • STEM Educators and Teaching
  • Materials and Chemical Engineering
26K
