MHB What Tension is Required for a 10 kg Mass to Hang Motionless?
  • Thread starter Thread starter WMDhamnekar
    Functions
The discussion focuses on calculating the tension required for a 10 kg mass to hang motionless from two wires at a 30-degree angle with the horizontal. The gravitational force acting on the mass is 98 N, and for equilibrium, the sum of the vertical components of the tension must equal this force. The tension in each wire is derived using the formula T = mg / (2sin(30)), leading to a tension of 98 N in total. Participants confirm that as the angle increases, the tension decreases, with the minimum tension occurring when the wires are vertical. Ultimately, the required tension for the mass to remain motionless is established as 98 N.
WMDhamnekar
MHB
Gravity acting on a 10 kg,mass produces a force of $F_g=\langle 0, -98\rangle$ Newtons. If the mass is suspended from 2 wires which both form $30^\circ$ angles with the horizontal, then what forces of tension are required in order for the mass to hang motionless over time?
Answer.
I computed $F_{net}=\langle 0,-98+F\rangle$. Now how to compute the final answer? For equilibrium,$F_{net}=0$
Answer.
I comuted $F_{net}=\langle \frac {\sqrt{3}-1}{2},-98+\frac{(\sqrt{3}+1)*F}{2}\rangle$. Now how to compute the final answer? For equilibrium,$F_{net}=0$
sum of the magnitudes of each vertical component of tension upward = magnitude of gravity force downward
$2T\sin(30) = mg$
$T = \dfrac{mg}{2\sin(30)} = mg$
$2T\sin(30) = mg$
Hello,
So $F=\frac{98}{\sqrt{2}}=69.2965N$ approx. Isn't it?
Hello,
So $F=\frac{98}{\sqrt{2}}=-69.2965$ approx. Isn't it?
No ... magnitude of tension in each wire oriented 30 degrees from the horizontal is $T = mg = 98 \text{ N}$
As the angle from the horizontal increases, the tension decreases. If both wires are vertical ($\theta = 90^\circ$), the tension is a minimum ...
$T = \dfrac{mg}{2\sin(90)} = \dfrac{98}{2} = 49 \text{ N}$
Is my computed answer for $F_{net}$ is correct?
The system is in equilibrium ...
$\displaystyle \sum F_x = 0 \text{ and } \sum F_y = 0 \implies F_{net} = 0$
So, the final answer for the forces of tension required in order for the mass to hang motionless over time is 98N.
does the attached sketch confirm your statement?
  • · Replies 30 ·
  • · Replies 18 ·
