What to do with a mathematic equation
  • Thread starter RabbitWho
  • Tags
    Mathematic
In summary: You correctly applied the equation and solved for the distance traveled by the ball after 4 seconds. The half in the equation comes from the fact that the acceleration due to gravity is constant and the ball is traveling in a parabolic path. Integrating the acceleration function with respect to time gives you the displacement function, which has a coefficient of 1/2 in front of the acceleration term. In summary, using the formula d= v0t + 1/2at^2, you can solve for the distance traveled by a ball thrown upwards after 4 seconds, where v0 is the initial velocity and a is the acceleration due to gravity. The half in the formula comes from the integration of the acceleration function and represents the parabolic path
RabbitWho
153
A ball is thrown upwards at a speed of 29.4m/s
Where is it 4 seconds after being released.
d[/B]=v0t+1/2at2
So I understand what the letters all stand for because that information is explained, but I don't know what to do with it.
The answer is 39.2. I don't know how or why because I don't understand basic mathematics notation. If a and t are next to each other like that am I supposed to multiply them by each other?
But what about the half? Is it half of a (14.2), or is it half of a multiplied by t (58.8)? Then I multiply one of those numbers by itself because of the 2.. If I see a bunch of things together like that how do i know whether you multiply something by the next thing or the next 2 things or work with the others first then go back to that or... ?
so
d=0 (speed at beginning)x4
So that first part is just 0, right, i can ignore it? x 14.2 x 14.2 = 201.64... Argh I'm
Also, can someone tell me where the half comes from in the equation?If someone could do the sum with all (and i mean all!) the rough work I think I'd be able to pick up what I am supposed to do. I used to be able to do this but I haven't done anything except add and subtract in 12 years.
This seems like a nice Free-Fall physics problem. You have an upward initial velocity of 29.4 m/s and as it travels up, the only force acting on it (for this problem) is the force of gravity at 9.8 m/s/s downward (depending on your frame of reference).
The equation you used will solve the problem. This is a variation of some other constant acceleration equations.
d = distance traveled (your soln)
vo = initial velocity
t = time
a = acceleration (gravity in this case)
t^2 = time (again)
If a and t are next to each other and you have values for each, then yes, multiply them together. 1/2 x 9.8 x 4^2 can be evaluated in any order because multiplication is commutative (as long as you evaluate the 4^2 first).
I don't know how to derive this equation or others like it but I believe it comes from integrating... something... lol sorry can't be more helpful.
I JUST took mechanics so if anyone sees any flaws, please help us both out.
p.s. Maybe review some algebra axioms, so evaluating algebraic equations will be much easier. If you have the time check out, daabz.com and go over his algebrea 46 (I think it's 46) class. It's a proof based algebra class that covers the main axioms. I am in calc 3, linear algebra, discrete math atm, but I took this class on my own recently and it has sharpened my skills exponentially! He was my calc 2 prof.; very cool guy.
Chris
When "things" (numbers and other factors) are next to each other, that means multiply them together.
So 1/2at2 means: (1/2) X (a) X (t2)
Note: The speed at the beginning is not zero! You are given the speed.
Note 2: Take care with signs. Use + for up and - for down. (Given that, what would you use for the acceleration a?)
Likes TomHart and RabbitWho
Sorry about getting the starting speed wrong, I was thinking about earlier when the ball fell off something, so its starting speed was 0 then. I also had the speed and the acceleration mixed up, the acceleration must be -9.8m/s because it is fighting gravity.So half times a is -4.9.
4.9 x (4x4) = -78.4
Then the first half
d=29.4 x 4 + -78.4
d = 117.6 - 78.4
= 39.2
HA HA I DID IT :D
Thanks and thanks for your patience :)
My immense sense of satisfaction is quite disproportionate to the objective difficulty of the question, but I am still going to enjoy it :)
Likes TomHart and SammyS
Nice!
Likes RabbitWho
FAQ: What to do with a mathematic equation
What is a mathematic equation?
A mathematic equation is a statement that uses mathematical symbols to show the relationship between quantities or values.
What can you do with a mathematic equation?
A mathematic equation can be used to solve problems, make predictions, and explain relationships between variables.
How do you solve a mathematic equation?
To solve a mathematic equation, you need to follow certain rules and operations to isolate the variable you are trying to find. These rules include the order of operations, combining like terms, and balancing both sides of the equation.
Can you manipulate a mathematic equation?
Yes, a mathematic equation can be manipulated by using algebraic operations such as adding, subtracting, multiplying, and dividing. These operations will change the equation while keeping it balanced.
Why is it important to understand mathematic equations?
Understanding mathematic equations is important because it allows you to solve problems in various fields such as science, engineering, finance, and more. It also helps develop critical thinking and problem-solving skills.
