What topics are best for study of how gravity light works?
In summary: The idea is that third world countries who don't have electricity could use this as an affordable alternative. In summary, the gravity light is a device that utilizes gravitational potential energy to power a light. Unlike traditional methods of releasing this energy quickly, the gravity light slowly releases the energy over a period of time to power a light at a reasonable brightness. This is made possible by modern energy efficient LEDs and a small casing with reliable gearing. The concept of slowly releasing energy that would normally be explosive is the novel aspect of this invention. However, clocks powered by similar methods have been around for centuries. In terms of practicality, one would need to lift a weight of 50kg every 5 minutes to generate enough power to light a 5
stargateengineer
I've seen a little bit about the gravity light. I think it works in a simple way, a weight at a certain height has gravitational potential energy depending on how far the weight will fall, this quantity represents the total energy we have at our disposal to power a light. Now we normally think of something falling very quickly, releasing all that potential energy in less than a second. But that is the ingenious aspect of the gravity light. The inventors figured, why not slowly release that gravitational potential energy over a period of time, at a rate which will be just enough to power a light at a reasonable brightness for a reasonable amount of time. Fascinating!
I would like to delve in a little bit into the physics that makes this possible. The mathematics involved. The thing that really pops out at me is the idea of slowly releasing the energy of a process that would normally be an explosion of energy over a very short time.
Science news on Phys.org
what's gravity light ?
you post sounds like scifi
The comparison to an open wick kerosene lamp (no mantle) is more a testament to the weak light produced by a kerosene lantern than to the output of a gravity light. One tenth of a watt is not much.
Clocks powered this way have been around for centuries. So that is not really the novel thing here, but rather combining it with modern energy efficient LEDs, in a small casing (design small but reliable gearing to provide high RPMs to the generator).
Likes DrClaude
I was surprised to learn that the LED limited the power flowing through the circuit to regulate the rate at which the weight falls.
Well, to start, calculate the gravitational potential energy of the system with the GPE equation. Then just divide the result by the time of the fall to get the power produced (or vice versa).
@russ_watters and @A.T. Gave you very good answers. Wind up clocks are ancient. Water clocks are ancient. What is new is LED lights that work with so little power.
It's worth running some numbers before we all rush to cancel our electricity contract. Just how much weight do you have to lift? How high and how frequently? Here is an example...
A 40W Incandescent bulb or a 5W LED can produce about 450 Lumens. If you wanted it to operate your 5W LED for say 5 mins you would need the weight to store 1,500 Joules (5*5*60 =1500). Most houses have ceilings around 3m high so if you want your lamp to fit indoors the weight can't be lifted higher than that. To store 1500 Joules in a weight raised 3m the mass would have to be 1500/(9.81*3) = 50kg. So every 5 mins you have to put down your book and lift a 50kg weight 3m into the air.
Thomas Jefferson solved this problem by cutting a hole in his floor.
Not the supposed application of this, obviously.
Likes CWatters
Related to What topics are best for study of how gravity light works?
1. What is the main principle behind how gravity light works?
The main principle behind how gravity light works is the conversion of potential energy into kinetic energy. The light is powered by the force of gravity as it falls, which turns a gear mechanism and generates electricity.
2. How does gravity light compare to other sources of light?
Gravity light is a renewable and sustainable source of light, as it does not require any external energy source such as batteries or electricity. It is also much more cost-effective in the long run compared to other sources of light.
3. What are some potential applications of gravity light?
Gravity light has the potential to provide light to communities that do not have access to electricity, especially in developing countries. It can also be used as a backup source of light during power outages or in emergency situations.
4. How can studying gravity light contribute to our understanding of physics?
Studying gravity light can help us better understand the principles of energy conversion and the laws of motion. It can also lead to advancements in renewable energy technology and contribute to the development of more sustainable and efficient energy sources.
5. Are there any limitations to gravity light?
Gravity light is limited by the height at which it is placed, as the higher the light is lifted, the longer it will take to fall and generate electricity. It also requires a constant supply of gravity, so it may not be suitable for use in all environments.
13K
