What type of mathematical function is this? Thanks :)
In summary, John's oven temperature follows an exponential function, which can be modeled by the formula f(t)=-280\left(\frac{43}{56}\right)^t+350. Alternatively, a quadratic polynomial can be used to exactly fit the given data points, with the formula y= ax^2+ bx+ c.
Hawaiianboi808
John lives in Dallas and his kitchen has a room temperature of about 70 degrees fahrenheit. He wanted to make her family some cookies for dessert, so he preheated her oven to 350 degrees fahrenheit. In 1 minute, the oven was 135 degrees fahrenheit. In 2 minutes, the oven was about 200 degrees fahrenheit. In 4 minutes, it went up to about 300 degrees fahrenheit. John's cookie dough was ready to go in the oven about 10 minutes after he turned it on.
I believe that this is an exponential function. Not sure, please double check.
Include example of formula.
Thank you
Mathematics news on Phys.org
We could likely model this with a function of the form (which comes from Newton's Law Of Cooling):
\(\displaystyle f(t)=c_1e^{-kt}+350\)
Since we know $f(0)=70$, we then have:
\(\displaystyle f(t)=-280e^{-kt}+350\)
And we know $f(1)=135$, so we have:
\(\displaystyle f(t)=-280\left(\frac{43}{56}\right)^t+350=70\left(5-4\left(\frac{43}{56}\right)^t\right)\)
This doesn't fit the remaining points exactly, but it is the type of function we would expect. :D
If you want to exactly fit all points, given any n points, there exist a polynomial of degree n-1 that passes through each of those points. Here, there are three points, (1, 135), (2, 200), and (4, 300) so there exist a quadratic polynomial that passes through the three points.
Any quadratic polynomial can be written in the form [tex]y= ax^2+ bx+ c[/tex]. The data above gives [tex]135= a+ b+ c[/tex], [tex]200= 4a+ 2b+ c[/tex], and [tex]300= 16a+ 4b+ c[/tex]. Solve those three equations for a, b, and c.
FAQ: What type of mathematical function is this? Thanks :)
What is a mathematical function?
A mathematical function is a relationship between an input (or independent variable) and an output (or dependent variable) that assigns a unique output value for every input value. It is a fundamental concept in mathematics and is used to model real-world phenomena and solve problems.
How do you identify the type of mathematical function?
The type of mathematical function can be identified by its mathematical expression or equation. Some common types of functions include linear, quadratic, exponential, logarithmic, and trigonometric functions. By analyzing the form of the equation, you can determine the type of function.
What is a linear function?
A linear function is a mathematical function with a constant rate of change, meaning that the output changes at a consistent rate as the input changes. It can be represented by a straight line on a graph and has the form y = mx + b, where m is the slope and b is the y-intercept.
How do you graph a mathematical function?
To graph a mathematical function, you need to plot points that satisfy the equation and connect them with a smooth curve or line. The input values are plotted on the x-axis and the corresponding output values on the y-axis. You can also use a graphing calculator or software to graph more complex functions.
What are some real-world applications of mathematical functions?
Mathematical functions have numerous real-world applications, such as modeling population growth, predicting future trends, optimizing business operations, and designing computer algorithms. They are also used in fields like physics, engineering, economics, and statistics to analyze and solve problems.
