FGD
- 46
- 12
I am trying to add the magnus effect to a golf simulator program but am getting stuck on the coefficient of lift. What are the units I should be using in these calculations? The rest of my program I use SI units. But I seam to get weird results when using them with these equations.
Spin factor = Angular Velocity * radius / velocity
Coefficient of lift = -0.05 + sqrt(0.0025 + 0.36 * radius * abs[angular velocity/velocity])
I've seen angular velocity in rpm or rad/s or...
I've seen velocity in mph or m/s or...
I've seen radius in inches or meters or...
The Coefficient of lift formula is taken from this paper.
The Spin factor from this paper.
If I get the proper units it should provide a graph with similar results to these. Left coefficient of lift, bottom spin factor.
If you know of better research papers or source code, I would love a link.
An example problem would also be very helpful.
Thanks
Thanks
