What Value of a Makes Two Linear Equations Parallel?
In summary, the two equations given are 2x + ay = 1 and ax + (a+4)y = 2. To determine if they are parallel, we need to check their slopes by rewriting the equations in slope-intercept form. By setting the slopes equal to each other, we can find the possible values of a. Using the fact that parallel lines have equal ratios of their coefficients, we can also solve for a. The answer is a = -2.
ThomsonKevin
Hello everyone, I was wondering if someone could solve this and explain it in detail. The answer is supposed to be a= -2. Let's cut to the chase:
If the two lines 2x + ay = 1 and ax + (a+4)y = 2 are parallel ,what is a?
Mathematics news on Phys.org
Hello! (Wave)We can determine if two straight lines are parallel by checking their slopes.
Suppose that the equation for the first line is $y_1 = m_1x + b_1$ and the equation for the second line $y_2 = m_2x + b_2$.
For two lines to be parallel their slopes have to be same. That is, $m_1 = m_2$.
$$2x+ay=1 \Rightarrow ay=-2x+1 \overset{a \neq 0}{\Rightarrow} y=-\frac{2}{a}x+\frac{1}{a}$$
$$ax+(a+4)y=2 \Rightarrow (a+4)y=-ax+2 \overset{a \neq -4}{\Rightarrow} y=\frac{-a}{a+4}x+\frac{2}{a+4}$$So, it has to hold:
$$-\frac{2}{a}=\frac{-a}{a+4} \Rightarrow -2a-8=-a^2 \Rightarrow 2a+8=a^2 \Rightarrow a^2-2a-8=0$$Solve the equation $a^2-2a-8=0$ and you will find the possible values of $a$.
You can also use the fact that the lines $A_1x+B_1y+C_1=0$ and $A_2x+B_2y+C_2=0$ are parallel iff $A_1/A_2=B_1/B_2\ne C_1/C_2$. Here if $A_2=0$, then $A_1/A_2=B_1/B_2$ means, by definition, that $A_1=0$, and similarly for $B_1$, $B_2$.
Yes, exactly what I needed, thank you both of you!
Sure, I'd be happy to help solve this problem and explain the steps involved. First, let's start by defining what a linear function is. A linear function is a type of mathematical function that can be represented by a straight line on a graph. It follows the form y = mx + b, where m is the slope of the line and b is the y-intercept.
Now, let's look at the two given lines: 2x + ay = 1 and ax + (a+4)y = 2. We can rewrite these equations in the form y = mx + b by solving for y:
2x + ay = 1
ay = -2x + 1
y = (-2/a)x + 1/a
ax + (a+4)y = 2
(a+4)y = -ax + 2
y = (-a/a+4)x + 2/(a+4)
Notice that both equations have the same slope, -2/a. This means that the lines are parallel, since parallel lines have the same slope. Now, in order for the lines to be parallel, the y-intercepts must also be the same. This means that 1/a = 2/(a+4).
To solve for a, we can cross-multiply and simplify the equation:
1/a = 2/(a+4)
(a+4)(1/a) = (a+4)(2/(a+4))
a + 4 = 2
a = -2
Therefore, the value of a that makes the two lines parallel is -2. I hope this explanation was clear and helpful. Let me know if you have any further questions.
FAQ: What Value of a Makes Two Linear Equations Parallel?
What is a linear function problem?
A linear function problem is a mathematical problem that involves finding the relationship between two variables that can be represented by a straight line. It often involves finding the slope and y-intercept of the line, as well as identifying the independent and dependent variables.
How do I solve a linear function problem?
To solve a linear function problem, you will need to use the formula y = mx + b, where m is the slope and b is the y-intercept. You will also need to plug in values for the independent variable and solve for the dependent variable. Lastly, you will need to plot the points on a graph to visualize the relationship between the two variables.
What are some real-life applications of linear function problems?
Linear function problems can be used to model real-life situations, such as calculating the cost of a phone plan based on the number of minutes used, predicting the growth of a population over time, or determining the speed of a moving object.
What is the difference between a linear function and a nonlinear function?
A linear function has a constant rate of change, meaning the slope remains the same throughout the entire line. A nonlinear function, on the other hand, has a varying rate of change, meaning the slope changes at different points on the graph. Nonlinear functions can take various shapes, such as a curve or a parabola, while linear functions are always straight lines.
Can linear function problems have more than two variables?
Yes, linear function problems can have more than two variables. In fact, the general form of a linear function is y = mx + b, where m is the slope and b is the y-intercept, and x and y are variables. This means that any number of variables can be added to the equation, as long as they are all related to each other by a constant rate of change.
