What values of a satisfy the cubic equation $a^3+23$ being a multiple of 24?
  • MHB
  • Thread starter Albert1
In summary, for the given conditions of $a>0$, $a\in N$, and $a<100$, the only possible solutions for $a$ to make $a^3+23$ a multiple of 24 are 1, 25, 49, 73, and 97. This is because 24 is even and 23 is odd, therefore $a$ must be odd and less than 5. By solving the cubic equation, the solutions for $a$ are found to be 1, 25, 49, 73, and 97. The minimum value of $a$ is 1 and the maximum value is 97.
Albert1
1,221
$a>0,\,\, a\in N,\,\, and \,\, a<100$
if $a^3+23 $ is a multiple of 24
$find \,\, a$
Mathematics news on Phys.org
$find \,\, a$
[sp]Because 24 is even and 23 is odd, a must be odd and is a<5... then 1 is solution and 3 isn't solution...[/sp]
Kind regards
$\chi$ $\sigma$
Kind regards
$\chi$ $\sigma$
why a<5 ? (a<100 is given)
All right!...
[sp]You can find a solving the cubic equation...
$\displaystyle a^{3} - 1 = (a - 1)\ (a^{2} + a + 1) \equiv 0\ \text{mod}\ 24\ (1)$
Now $\displaystyle a - 1 \equiv 0\ \text{mod}\ 24$ has the only solution $\displaystyle a\ \equiv 1\ \text{mod}\ 24$ and that means a=1, 25, 49, 73, 97...
Otherwise $\displaystyle a^{2} + a + 1 \equiv 0\ \text{mod}\ 24$ has no solutions because in both cases 'a even' and 'a odd' the expression $\displaystyle a^{2} + a + 1$ gives an odd number and 24 in even, so that the solution found in the previous step are the only solutions...[/sp]
Kind regards
$\chi$ $\sigma$
chisigma said:
All right!...
Kind regards
$\chi$ $\sigma$
yes ,you got it !
for $a\in N , 0<a<100$
and $\displaystyle a\ \equiv 1\ \text{mod}\ 24$
so $,min(a)=1,max(a)=97$
$a=1,25,49,73,97$
FAQ: What values of a satisfy the cubic equation $a^3+23$ being a multiple of 24?
What is a cubic equation?
A cubic equation is a mathematical equation that has the form of ax^3 + bx^2 + cx + d = 0, where a, b, c, and d are constants and x is a variable. It is called a "cubic" equation because the highest power of x is three.
How do you find the value of a in a cubic equation?
To find the value of a in a cubic equation, you can use the method of "completing the cube" or by using the general formula for solving cubic equations, which is x = (-b ± √(b^2 - 4ac + 27d^2))/2a. This formula is known as the "cubic formula" and can be used to find all three solutions for a cubic equation.
What is the difference between real and complex solutions in a cubic equation?
A cubic equation can have either real or complex solutions. Real solutions are values of x that make the equation equal to 0 when plugged in, while complex solutions involve the use of imaginary numbers. Complex solutions occur when the discriminant (b^2 - 4ac + 27d^2) is negative.
Can you use the quadratic formula to solve a cubic equation?
No, the quadratic formula can only be used to solve quadratic equations (equations with a highest power of x as 2). To solve a cubic equation, you need to use the cubic formula or other methods such as completing the cube or graphing.
What are the real-life applications of solving cubic equations?
Cubic equations are used in various fields of science, engineering, and economics. For example, in physics, they can be used to calculate the motion of an object under the influence of gravity. In chemistry, they can be used to determine the concentration of a solution. In economics, they can be used to model and predict market trends.
