What Values of k Make the Equation Have One Non-Negative Root?
  • MHB
  • Thread starter anemone
  • Tags
    2017
In summary, the equation that needs to be solved for one non-negative root is of the form ax^2 + bx + c = 0, where a, b, and c are constants and x is the variable. A non-negative root means that the value of x that satisfies the equation is either 0 or a positive number. To find the value of k that will result in one non-negative root, the discriminant (b^2 - 4ac) must be set to equal 0, and then solved for using the quadratic formula. It is possible for the equation to have multiple values of k that will result in one non-negative root, and finding these values is important in determining the number of solutions to the equation.
anemone
MHB
POTW Director
3,883
115
Hi MHB, sorry for missing one week of high school's POTW, I guess I can make it up by posting two POTWs this week.(Blush)
Here is this week's another POTW:
Find all values of $k$ such that the equation
$\left(\dfrac{1}{x+k}+\dfrac{k}{x-k}-\dfrac{2k}{k^2-x^2}\right)(|x-k|-k)=0$
has exactly one non-negative root.
Remember to read the http://www.mathhelpboards.com/showthread.php?772-Problem-of-the-Week-%28POTW%29-Procedure-and-Guidelines to find out how to http://www.mathhelpboards.com/forms.php?do=form&fid=2!
Congratulations to kaliprasad for his correct solution, which you can find below::)
Note that we cannot have $x = k$ or $x = -k$.
Multiply both sides by $ (x^2-k^2)$, we get
$((x-k) + k(x+k) + 2k) (\left| x -k \right| -k) = 0$
or $(x+k) (k+1) (\left| x -k \right| -k) = 0$
As $x$ cannot be $-k$ we have
$(\left | x -k \right| -k) = 0$
$|x-k | = k$, this gives 2 values of $x$, where $x = 0$ or $2k$.
Hence there is no solution to the problem.
FAQ: What Values of k Make the Equation Have One Non-Negative Root?
What is the equation that needs to be solved for one non-negative root?
The equation that needs to be solved is of the form ax^2 + bx + c = 0, where a, b, and c are constants and x is the variable.
What does it mean to have one non-negative root?
A non-negative root means that the value of x that satisfies the equation is either 0 or a positive number. In other words, there is only one solution to the equation that is either 0 or a positive number.
How do I find the value of k in the equation to make it have one non-negative root?
To find the value of k, you must first set the discriminant (b^2 - 4ac) of the quadratic equation to equal 0. Then, solve for k using the quadratic formula (x = (-b ± √(b^2 - 4ac)) / 2a). This will give you the value(s) of k that will result in one non-negative root.
Can the equation have more than one value of k that will result in one non-negative root?
Yes, it is possible for the equation to have multiple values of k that will result in one non-negative root. This can occur when the discriminant is equal to 0 and the quadratic formula results in two different values of x. In this case, both values of k will result in one non-negative root.
Why is it important to find values of k that will result in one non-negative root?
Finding values of k that will result in one non-negative root is important because it helps determine the number of solutions to the equation. If the equation has one non-negative root, it means there is only one possible value for x that satisfies the equation. This can be useful in solving various mathematical problems and applications.
