What was the mistake in solving for the speeds of two marbles after a collision?
The discussion centers on solving for the speeds of two marbles after an elastic collision. The initial calculations yielded an incorrect speed of 2.22 m/s for one marble, prompting confusion about which question it addressed. Participants emphasized the importance of showing work and suggested simplifying equations when one mass is at rest. A rounding error was noted as a potential issue, and ultimately, the correct answer was found to be due to an algebra mistake. Clear communication and detailed calculations are essential for solving such problems accurately.
anotherphysicsgeek
A 49.0 g marble moving at 1.90 m/s strikes a 28.0 g marble at rest. Note that the collision is elastic and that it is a "head-on" collision so all motion is along a line.
What is the speed of 49.0 g marble immediately after the collision?
What is the speed of 28.0 g marble immediately after the collision?
1. m1v1i+m2v2i=m1v1f+m2v2f
2. 1/2m1v1i^2+1/2m2v2i^2=1/2m1v1f^2+1/2m2v2f^2
Solved equation 1 for v1f and then substituted into equation 2 and solved for v2f. Got 2.22 as the answer, but it said the answer is incorrect.
anotherphysicsgeek said:
Homework Statement: A 49.0 g marble moving at 1.90 m/s strikes a 28.0 g marble at rest. Note that the collision is elastic and that it is a "head-on" collision so all motion is along a line.
Relevant Equations: 1. m1v1i+m2v2i=m1v1f+m2v2f
Got 4.4333 as the answer
This is the answer to what? There are two questions.
Sorry it was the answer to the second question. Also going back and re-plugging in the numbers I got 2.22, but it's still wrong.
You need to show your work. Also, take a look at the Latex guide for maths equations, under the help pages.
In a question like this, where one mass is initially at rest, I would automatically simplify the relevant Equations. If you reply to this post, you'll see the Latex I used. I prefer ##u, v## to ##v_i, v_f##. E.g.
$$m_1u_1 = m_1v_1+m_2v_2$$$$\frac 1 2 m_1u_1^2 = \frac 1 2 m_1v_1^2 +\frac 1 2 m_2v_2^2$$
That's not far off. Maybe a rounding error. Keep at least three sig figs until the end.
But it is silly having to guess. As @PeroK says, post your working.
Thank you guys, and I'll fix that in the future. I ended up finding the correct answer and it was an algebra mistake.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
