Micheal_Leo
- 66
- 4
so 6 on main scale and 0.34 on dial . on main scale i am seeing cm scaleBaluncore said:That is not a vernier caliper, it is a dial caliper.
If you zeroed the dial before the reading, it reads 6.34 mm.
It is very close to 1/4" = 6.35 mm.
Each mark on the bar is one millimetre. The reading is just over six.
The dial turns once every two millimetres.
The even millimetre zero is at the top of the dial.
The odd millimetre zero is at the bottom of the dial.
That appears to be subdivided into 1 mm divisions.Micheal_Leo said:on main scale i am seeing cm scale
got it thank you so 6.34cmBaluncore said:That appears to be subdivided into 1 mm divisions.
The 5 mm mark is slightly longer, as will be the 10 mm marks.
If the 10 mm multiples are marked 0, 1, 2, 3, 4 ... then it is in centimetres.
If the marks are 0, 10, 20, 30, 40 ... then it is in millimetres.
That measured distance is less that 1 cm (10 mm), so it can’t be that value.Micheal_Leo said:got it thank you so 6.34cm
No, it's 6.34mm. No instrument, however accurate, is useful without the user's common wisdom, sorry to be so blunt.Micheal_Leo said:got it thank you so 6.34cm
