What will happen in this situation
  • Thread starter irphysics
In summary, if a man jumps inside a train while it is traveling at a constant velocity and in a straight line, he will land in the same spot he took off from. However, if the train is moving in a curved path or changes its velocity while the man is in the air, he will land in a different spot. This is due to the principles of Newton's First Law and the effects of drag on the man's body.
irphysics
What will happen if a man jumps inside a train.Will the train move forward and the man land up in different place.Sorry for my bad English.
However long it takes for the man to jump, from the ground onto the train, the train will have moved x = vt (where t is that time and v is the velocity of the train). So yeah, the spot will have moved, and it will have moved a lot if the train is going very fast.
Furthermore, since the train has a lateral velocity and the man does not (i.e. the man does not have any velocity in the direction of the train's velocity), when the man's feet land on the train, they will be pulled with the motion of the train and he may fall over if he doesn't shift his center of gravity appropriately.
Of course, if you're riding along side the train in a horse and keeping up with it perfectly, then you'll have velocity in the direction of the train, so when you jump it will be as if you jumped from one stationary object to another (ignoring wind and air resistance).
Inside a train?
Pythagorean said:
However long it takes for the man to jump, from the ground onto the train...
I'm pretty certain the OP is talking about a person that is already riding in the train simply jumping straight up inside the train.
Not that your examples don't clearly illustrate the principles and answer the question. I wonder if the OP can figure out an answer from what you've already posted.
yes,the man is riding train.Should i try this
You have to ask yourself "What is there to slow the man down during his jump?"
If there is nothing then he will keep traveling at the same speed as the train, landing on the same spot he took off. Newton's First Law
If the train is open-topped or he's standing on the roof like James Bond, then there may be some drag, caused by his movement (at 60mph) through the air, acting on his body which will slow him down a bit once he is no longer in contact with the train and he may land a short way behind his starting mark on the train.
Depends if the train is traveling at a constant velocity and in a straight line.
If the train is going round a bend to the left when the man jumps he will land to the right.
The amount of deflection depends depends on how much the train traveled to the left when he is airbourne.
Likewise he will land in a different spot if the train speeds up or slows down whilst he is airbourne.
Yeah, it's a good thing that with constant, linear speed you will fall to the same spot, else imagine the chaos if I jumped or threw something up into the air while inside a passenger jet going a smooth 600mph!
splat!
FAQ: What will happen in this situation
What will happen if I mix these two chemicals together?
The result of mixing two chemicals together will depend on the nature of the chemicals and their reaction with each other. It can range from a simple physical change to a chemical reaction that releases heat or produces new substances. It is important to follow proper safety precautions and consult a chemical reference guide before mixing any chemicals.
What will happen if I conduct this experiment in a different environment?
The outcome of an experiment can be affected by the environment in which it is conducted. Factors like temperature, pressure, and humidity can influence the results. Conducting an experiment in a different environment may lead to different results, making it important to control and document the environment in which an experiment is performed.
What will happen if I change one variable in my experiment?
Changing one variable in an experiment can have a significant impact on the outcome. It is important to only change one variable at a time to accurately determine its effect on the experiment. Additionally, it is important to have a control group that remains unchanged to compare the results to.
What will happen if I repeat this experiment multiple times?
Repeating an experiment multiple times can help to ensure the accuracy and reliability of the results. It allows for any errors or inconsistencies to be identified and corrected. Repeating an experiment also helps to establish a pattern or trend in the results, making them more conclusive.
What will happen if I use a different method to conduct this experiment?
Using a different method to conduct an experiment may lead to different results. It is important to carefully consider and choose a method that is appropriate for the experiment being conducted. If a different method is used, it is important to document and explain the differences in the results obtained.
