What will happen when a body is equally dense as the liquid?
In summary, if an object is less dense than the liquid it will sink, and if it is equal to or greater in density than the liquid it will float. Displacement theories help to explain why this happens.
RS_Physics
I am studying Floatation in school and I have some doubts. I get that if an object is denser than the liquid its placed on, it will sink, and if it is less dense then it floats. But what happens when the density of both (the object and the liquid) are same? Will it float or sink?
My notes say that if it has a lesser density, then it float PARTIALLY &
if it has an equal density to that of the liquid it will FLOAT.
But how and why? I searched the net and found different explanations that confused me even more. Hope you can help.
KUDOS. :D
Read up on "Displacement". For example ships.
If the liquid is water, and the body has the same density as water, then it will most likely float because of the surface tension of water caused by hydrogen bonds.
If an object is exactly the same density as the liquid, it will not move up or down. It will just stay right where it is (unless it is pushed around by water currents). If you put it on the surface, it will remain on the surface [EDIT: see CWatters post below for clarification]. If you push it under the water, it will stay under the water, without moving up or down.
It's not so easy to achieve neutral buoyancy exactly. Fish and submarines do it by having an internal container that they can pump air and water into or out of in order to change their density.
If an object is exactly the same density as the liquid, it will not move up or down. It will just stay right where it is (unless it is pushed around by water currents). If you put it on the surface, it will remain on the surface.
Perhaps best to clarify that last line.. It will actually sink into the water so that no part of the object is above the surface.
There are three cases..
If an object is less dense than water it will sink into the water until the mass of water displaced equals the mass of the object. If pushed further under it will float back up.
If the object is of equal density it will sink into the water so that no part of the object is above the surface. It may or may not "float" just but entirely below the surface. As eigenperson said, if pushed down it might stay at the new depth but that's tricky.
If the object is of greater density it will sink.
Why is it tricky? If pushed down it will stay at the new depth unless acted on by another force. The force of water pressure would be equal on all sides would it not? Although there is less pressure exerted on it near the surface than there would be at greater depth. But that could be negligible depending on the size of the object. Also at such negligible magnitude of forces doesn't gravity still play a role? On second thought maybe you're right, this could get tricky ;) But tricky is interesting.:approve:
What I meant was it's hard to achieve exactly neutral buoyancy in the first place. Any slight error in the density and the object starts to float or sinks. If the object is slightly compressible then changes in water pressure may change it's volume slightly and hence it's density. Even temperature changes may effect it. This effect is exploited here.
http://www.howstuffworks.com/question663.htm
As the temperature changes a bubble will transition through the neutral density point and either float or sink.
Related to What will happen when a body is equally dense as the liquid?
1. What does it mean for a body to be equally dense as the liquid?
When a body is equally dense as the liquid, it means that the mass of the body per unit volume is the same as the mass of the liquid per unit volume. In other words, the body will neither sink nor float in the liquid, but will remain suspended at a certain depth.
2. How is the density of a body and the density of a liquid determined?
The density of a body is determined by dividing the mass of the body by its volume, while the density of a liquid is determined by dividing its mass by its volume. Both are expressed in units of mass per unit volume (such as g/cm3 or kg/m3).
3. What factors can affect the density of a body and a liquid?
The density of a body is primarily affected by its composition and internal structure, as well as temperature and pressure. The density of a liquid is primarily affected by its composition and temperature, but can also be influenced by pressure and the presence of impurities.
4. What happens when a body is equally dense as the liquid it is in?
When a body is equally dense as the liquid it is in, it will experience a balanced force from the liquid, causing it to remain suspended at a certain depth. This is known as neutral buoyancy. If the density of the body or liquid changes, the body will either sink or float.
5. Can a body be equally dense as multiple liquids at the same time?
Yes, a body can be equally dense as multiple liquids at the same time if its density is lower than one liquid and higher than the other. This can be observed in the case of oil and water, where some objects will float at the interface of the two liquids due to their density being between that of oil and water.
  • Other Physics Topics
  • Astronomy and Astrophysics
