What would a design prototype research paper look like?
In summary, a design prototype research paper would typically include an introduction outlining the research problem, objectives, and significance of the study. It would detail the design methodology, including the development process of the prototype and the tools used. The paper would present findings from user testing or evaluations, discussing the effectiveness and usability of the prototype. Additionally, it would analyze feedback and suggest improvements, concluding with implications for future research and practical applications. Proper citations and a review of relevant literature would support the research, ensuring a comprehensive framework for the study.
al4n
I have minimal to no research experience (writing / conducting) so I might be asking basic or silly questions. However, I am desperate as I have an upcoming paper to write and have close to zero ideas on where to begin. I am confused on a lot of things and I am hoping that a few of them will be cleared up.
To begin, the paper is required to be a design prototype of some kind ( Im not even sure if the term "design prototype" makes sense in this context, im just spewing out words that closely relates to what the expected output is), most likely of a mechanical system.
Now, in my surface level understanding, most papers of any kind must include one important thing: The question to ask. I think its technically called the problem statement or maybe the hypothesis.
Here is my first roadblock. What question do you even ask given the specifics of the paper. What variables are you supposed to measure? What are you supposed to test?
A prototype implies that its something new. If something new was created. What am I testing this new thing against? Pre existing things that are similar to it? What if its totally radical and can't be compared?
What if the goal is just to show the concept of the design to work? What data would then even need to be collected? Will one entire section of the paper be just two checkboxes that say either: "it works" or "it doesnt work".
Another method that I could think of is comparing the final version of the design to previous versions. However that would require creating multiple prototypes. Something that I would very much like to avoid for resource reasons.
I have a lot of other little things to ask but those are like the main things that I am really confused about. Hoping for answers
It seems you are missing some direction from your course. How is it you have a paper to write so soon but have so little guidance? What is this prototype you're supposed to design?
Likes berkeman
I dont wanna get into it, but the professor barely shows up and just gives some requirements. As for the specifics of the paper, its pretty much whatever you could think of, as long as you can back it up on how such a system may be ( or may not be) helpful.
OK, I think we're gonna need more than that to go on.
There's go to be some guidelines to help you get started.
Do you have any ideas so far about what you want to address?
I will attempt to describe, from my understanding, the output that is to be expected. It involves the design and development of either a tool, a machine, a mechanical system, or maybe even a process or method with the emphasis that it could lessen the tediousness or increase the convenice of a certain task. It may add upon previous design and ideas, or might be an entirely new concept. It is also a plus if the result has practical benefits to commercial or industrial sectors. The actual instructions were pretty vague, but in essence I think this is the goal.
OK, so we can deduce then that this is a mechanical engineering course maybe? Or product design course maybe?
Yes, this is a mechanical engineering course.
Do you have a 3D drafting program available to you as part of this course? Do you have a 3D printer available to fabricate designs from that program?
When thinking about an assignment like this, it is often useful to think about things you would like to make for your hobbies and daily life activities. Is there anything that frustrates you sometimes that you think there should be a better solution for?
It also could just be an idea you have had for a better solution to a common problem or a way to simplify daily activities.
I appreciate the feedback. I am still looking for a specific idea to pursue at the moment, however I would like clear up some points beforehand that I mentioned above about the the paper itself and how one would write it given the conditions. I think there may be 3D drafting programs that are opensource and readily available. I do not however have access to a 3d printer.
FAQ: What would a design prototype research paper look like?
What is the structure of a design prototype research paper?
A design prototype research paper typically includes an abstract, introduction, literature review, methodology, results, discussion, conclusion, and references. The structure may vary slightly depending on the specific requirements of the journal or conference.
What should be included in the abstract of a design prototype research paper?
The abstract should provide a concise summary of the paper, including the research problem, objectives, methods, key findings, and conclusions. It should be brief, usually around 150-250 words, and give readers a quick overview of the study.
How do you present the methodology in a design prototype research paper?
The methodology section should detail the design process, including how the prototype was developed, the materials and tools used, and any testing or evaluation methods employed. It should provide enough information for others to replicate the study.
What kind of results are typically included in a design prototype research paper?
The results section should present the findings from testing or evaluating the prototype. This may include quantitative data, qualitative observations, user feedback, and any performance metrics. Visual aids like charts, graphs, and images of the prototype can be very helpful.
How should the discussion and conclusion be structured in a design prototype research paper?
The discussion should interpret the results, explaining their significance and how they relate to the research questions. It should also address any limitations of the study and suggest areas for future research. The conclusion should summarize the main findings and their implications, reinforcing the contribution of the research to the field.
