What would be the ideal cross section of an axially loaded cantilever beam?
The discussion focuses on the ideal cross section for an axially loaded cantilever beam, emphasizing the role of moment of inertia in buckling resistance. A high moment of inertia, such as that found in I-beams, theoretically allows for greater critical loads before buckling occurs. However, the optimal design is application-specific, requiring analysis of various failure modes including tensile yield, compressive yield, and buckling. The process involves starting with simple shapes and optimizing them through iterations to find the lightest possible beam that meets all failure criteria. Tapered designs may offer weight advantages despite higher fabrication costs, highlighting the complexity of achieving an ideal beam cross section.
Johnstonator
Pretty much the title. Just some brain teasers I'm trying to figure out.
I can't think of how a cross section would come into play when it comes to axial loading. Buckling? Since the critical force for buckling is proportional to moment of inertia, so theoretically if I have a high moment of inertia about a specfic axis (like an I beam) the greater the critical force I can apply, thus "ideal"?
But then again, I could have a very large rectangular or circular solid beam and handle axial loading but how would I determine if it's ideal or not?
The answer is an application specific optimization. A beam is loaded with a bending moment. It may have an axial load. You have to analyze for all possible failure modes.
Some (not all) failure modes include tensile yield, compressive yield, compressive buckling, and web crippling. The optimal structural member will be designed so that it almost fails by every possible failure mode at the same time when it is subjected to the maximum load. You take a cross section, such as I-beam or rectangular box, then optimize it. Then take another cross section and optimize that. Repeat until you find the lightest possible beam.
How to optimize: Start with a simple shape, such as a circular tube. A thick wall tube will fail by yielding. A thin wall tube will fail by buckling. Somewhere in between is a wall thickness and diameter where the yield failure load will be the same as the buckling failure load. That tube will be the optimal circular tube. Then repeat with a rectangular box tube, an I-beam, etc.
An example of an optimal structure is the well known poem about the (fictional) One Hoss Shay: https://rpo.library.utoronto.ca/content/deacons-masterpiece-or-wonderful-one-hoss-shay-logical-story.
Likes jack action, Lnewqban, hutchphd and 2 others
Your analysis has made an assumption that the beam section will remain constant. A tapered truss able to do the same job, would cost more to fabricate, but would weigh less than a standard section.
Here's a video by “driving 4 answers” who seems to me to be well versed on the details of Internal Combustion engines. The video does cover something that's a bit shrouded in 'conspiracy theory', and he touches on that, but of course for phys.org, I'm only interested in the actual science involved. He analyzes the claim of achieving 100 mpg with a 427 cubic inch V8 1970 Ford Galaxy in 1977. Only the fuel supply system was modified. I was surprised that he feels the claim could have been...
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
