- #36
marksesl
- 56
DrChinese said:As mentioned, if you start with the idea that the photon is a wave: then interference makes perfect sense. But that same photon is quantized and appears at a single point only, giving it particle-like properties. So there are elements of both.
Your reasoning is circular about the importance of the experiment though. You can see that the behavior is fundamentally different when you cannot determine which of 2 slits the light traverses. Such matches the classical view of light as a wave, and what you make of that is up to you. I appreciate that all of this is "self-evident" to you but that is hardly the case for most. For example, the classical view of light as a wave is strictly ruled out in this experiment:
http://people.whitman.edu/~beckmk/QM/grangier/Thorn_ajp.pdf
Not so obvious.
I appreciate your discussion, but there can be no doubt that light and even a single photon is a wave. Photons, as you know, are produced by the quantum fall of electrons in atoms. It is during that fall that a photon's frequency is determined, imparting the very color the photon will have. All photons have an inherent frequency and wavelength. They are waves, but of discrete energy packets which give a particle quality as well. The assumption I'm making is not that light (photons) are waves, that's a given, but that as waves, photons can travel through both slits at the same time. The experiment is flawed, not because I'm assuming that light is wave, but because it is assuming that light is only discrete particles that cannot go through both slits, and by making that false assumption it is thought the photons can be correctly determined as to which way they actually traveled. But, if they do actually go through both slits, the experiment automatically destroys that "both-way" information because waves at right-angles cannot interfere anyway. The experiment eliminates one of the three possibilities, left, right, or "both." And, in eliminating the "both" option, it indirectly destroys knowledge of left or right as well because if the photons do in fact go through both, then left or right knowledge must be something the experiment just makes appear to happen. I'll read the article you linked to though.
