What would happen if you let a full battery charge an empty
In summary, the conversation discussed the potential risks and outcomes of using a full battery to charge an empty one using the same type of batteries. The main concern was the possibility of wire melting or battery explosion due to the difference in voltage. While a YouTube video of someone attempting this was requested, it was ultimately deemed unnecessary as the danger was fully understood. A safer method was proposed, involving the use of a resistor and heat sink to control the rate of discharge and recharge. A previous miscalculation was also addressed and corrected. The conversation was then concluded with the understanding that playing with battery charging in this manner is not advisable.
stargazer193857
33
Suppose you have a full battery and an empty one, both the same type, and you hook up positive to positive and negative to negative, and for this particular battery chemistry, the difference in voltage is great enough to commence charging of the negative one. How much current would likely travel between them? Wire melting / battery cooking current, or a more controlled rate of discharge / recharge?
Well, mrBigGuy told me by PM that a similar set up would go ka-bam.
So I will not try that myself.
But I would really like to see a you-tube video of someone else doing it. I know there has to be someone who tried it, given all the skateboard crashes on you tube. But what keywords to use.
Anyone want to link me to such a video of one battery charging another and exploding?
Never mind. No You-Tube video is needed. I now fully believe how dangerous it is. Probably a much safer way to do it is to put a resister between the batteries scaled to the voltage difference, and put a heat sink on the resister. I thought of that idea before, but I abandoned it because of a silly math error. Suppose the voltage difference is 1.5v and a 3 Ohm resister is used to get 0.5 amps. I then calculated the voltage drop across the resister: V = IR = 0.5 x 3 = 1.5v. I incorrectly concluded that the 1.5v drop across the resister would consume the whole 1.5v difference between them, preventing any charging. After thinking about that some more, and now realize the 1.5v drop is the same drop that was there before, and current would still be 0.5A (and decreasing). If the current were somehow zero, the resister voltage drop would decrease to zero, contradicting the assumption.
Of course I'd never play with something like this. I'm just trying to understand the physics.
Thread is closed.
The amount of current that would travel between the two batteries depends on several factors, including the type of battery and its chemistry, the size of the batteries, and the resistance of the wires connecting them. In general, when connecting a full battery to an empty one, the current flow will be high initially as the empty battery attempts to catch up to the charge level of the full battery. This could potentially cause the wires to melt or the batteries to overheat if the current is too high.
However, most modern batteries have built-in safety mechanisms to prevent this type of overcharging. They may have internal resistance or circuitry that limits the flow of current, preventing the wires from melting or the batteries from overheating. In this case, the charging process would be more controlled and the batteries would recharge at a slower, safer rate.
It is important to note that attempting to charge a battery with a significantly higher voltage than its own can be dangerous and may cause damage to the battery or other equipment. It is always best to use batteries and chargers that are specifically designed and rated for each other to prevent potential hazards.
FAQ: What would happen if you let a full battery charge an empty
What would happen if you let a full battery charge an empty?
The outcome of letting a full battery charge an empty one depends on various factors, such as the type of battery, the charging method, and the quality of the batteries. However, in general, the following things may happen:
Will the empty battery be charged?
If both batteries are of the same type and voltage, the empty battery will most likely be charged. However, if the batteries are of different types or voltages, the empty battery may not be able to charge or may become damaged.
Will the full battery lose its charge?
If the batteries are connected in parallel, there is a possibility that the full battery may lose some of its charge to the empty one. This is known as self-discharge and can happen due to the difference in voltage between the two batteries.
Is it safe to let a full battery charge an empty one?
In most cases, it is safe to let a full battery charge an empty one. However, it is important to ensure that the batteries are of the same type and voltage, and that the charging method is appropriate for both batteries. Using mismatched batteries or improper charging methods can result in damage to the batteries or even cause a fire.
Will the charging time be affected?
If the batteries are connected in series, the charging time will be affected. This is because the voltage of the two batteries will add up, and the charging current will be divided between them. As a result, the charging time will be longer compared to charging a single battery.
Can this process damage the batteries?
If the batteries are of different types or voltages, or if the charging method is not appropriate for both batteries, it can result in damage to one or both of the batteries. It is important to use matching batteries and proper charging methods to avoid any potential damage.
