What would the weight of a column of water be at the center of the Earth?
In summary, the conversation discusses the concept of pressure increasing with depth and how it relates to Jules Verne's book A Journey to the Center of the Earth. The conversation also delves into the calculation of pressure for a column of air descending into a uniform sphere and how it differs for liquid and gas. The idea of temperature and its impact on pressure is also explored, with a comparison of the beliefs of the character in the book versus current scientific opinion. Finally, the conversation concludes with a mathematical equation for calculating air pressure at the center of the Earth based on different assumptions about temperature.
Donald E Sawyer
In reading Jules Verne's book A Journey to the Center of the Earth I came to a section where one of the characters questions if the massive weight of the air would be fatal at the center of the Earth. I lack the mathematical skills to derive an equation to graphically represent the results. My idea was to represent a column of water as it descended into a uniform sphere of significantly larger dimension.
You know that pressure increases with depth... that is often described as being due to the weight of the water above you... which is accurate.
This is what Verne was talking about (through a character who may or may not be wrong...)
Anyway ... gravity decreases linearly to zero as you approach the center of a uniform sphere.
You know the force at the surface (r=R) R^2 where M and R are the mass and radius of the sphere in question.
You know it is zero at r=0 ... and you know the graph is linear... and you know the equation for a straight line...
acceleration of gravity comes out as: g(r)= (GM/R^3)r = g(R)r/R
So the mass dm of water between r and r+dr experiences force g(r).dm ... add up all the "dm"'s.
The calculation is easier for a liquid (water) than it is for a gas (air) because the latter compresses under pressure whereas the former hardly does at all. To do the calculation for air requires using the Ideal Gas Law ##PV=nRT##. Further, to do the calculation one needs to know the temperature at all points in the air shaft, which will be mostly determined by the temperature of the walls.
Prof Lidenbrock in Verne's book believed that, contrary to mainstream scientific opinion at the time, the temperature never strayed very far from surface temperature as one traveled to the centre of the Earth. Indeed, if that were not the case, Arne Saknussem would never have survived the journey (unless he had lied about getting there - a question that is never resolved in the novel, as Lidenbrock never gets deeper than about 50km).
In contrast, now scientific opinion is that the temperature at the centre of the Earth is more than 5000 degrees C. That makes for much less dense, and hence lighter, air, giving a much lower pressure at the centre than Lidenbrock would have calculated.
Assume the column is straight and has cross-sectional area of one square metre. The actual area or direction of the hole makes no difference, but the calculations are easier that way. We can calculate the contribution ##dP## to pressure (weight per unit area) from a section of the column of air of height ##dx## at depth ##x## below the Earth's surface as:
$$dP= m\,g(x)n(x) dx
=m(D-x)g_s\frac{ P(x)dx}{RT(x)}$$
where ##D## is the Earth's radius, ##g_s## is the gravity at Earth's surface (about 9.8 ##ms^{-2}##) and ##m## is the average molecular mass of air.
Using separation of variables, we can re-write this differential equation as:
$$\frac{dP}P = \frac{mg_s}R \frac{(D-x)dx}{T(x)}$$
so that
$$\log \frac{P_c}{P_s} = \frac{mg_s}R \int_0^D \frac{(D-x)dx}{T(x)}$$
where ##P_c,P_s## are the air pressure at the centre and the surface of the Earth respectively, so that
$$\frac{P_c}{P_s} = \exp\left(\frac{mg_s}R \int_0^D \frac{(D-x)dx}{T(x)}\right)$$
Under Lidenbrock's (erroneous) assumption of approximately constant temperature ##T## along the shaft, this is
$$\exp\left(\frac{mg_s}{RT} \int_0^D (D-x)dx\right)
=\exp\left(\frac{mg_s}{RT} [Dx-x^2/2]_0^D\right)
=\exp\left(\frac{mg_sD^2}{2RT} \right)
Alternatively, assuming the temperature increases linearly from say 20 degrees to 6020 degrees C along the shaft (293 to 6293 Kelvin) the calculation is
$$\frac{P_c}{P_s} = \exp\left(\frac{mg_s}R \int_0^D \frac{(D-x)dx}{293+6000x/D}\right)$$
for which the integral is evaluated easily on Wolfram Alpha if you're lazy like me.
Plug in the values of ##D, m, g_s, R## and we'll have the answer. I expect Lidenbrock's number to be much bigger.
FAQ: What would the weight of a column of water be at the center of the Earth?
What is the weight of a column of water at the center of the Earth?
The weight of a column of water at the center of the Earth would be approximately 9,800,000,000,000,000,000,000,000 kilograms. This is because the force of gravity increases as you get closer to the center of the Earth, making the weight of objects at the center much greater than at the surface.
How is the weight of a column of water at the center of the Earth calculated?
The weight of a column of water at the center of the Earth is calculated using the formula W = mg, where W is weight, m is mass, and g is the force of gravity. The force of gravity at the center of the Earth is approximately 10,000 times greater than at the surface, hence the extremely large weight calculation.
Does the weight of a column of water at the center of the Earth change with depth?
Yes, the weight of a column of water at the center of the Earth does change with depth. As you go deeper towards the center of the Earth, the force of gravity increases, resulting in a greater weight calculation for the column of water.
How does the weight of a column of water at the center of the Earth compare to the weight at the surface?
The weight of a column of water at the center of the Earth is much greater than the weight at the surface. This is due to the increase in gravitational force as you go deeper towards the center of the Earth.
Why is the weight of a column of water at the center of the Earth important to know?
The weight of a column of water at the center of the Earth is important to know for various scientific and engineering purposes. It can help in understanding the Earth's structure and composition, as well as in designing structures that can withstand the immense weight and pressure at the center of the Earth.
