Whatever happened to Intentional Programming paradigm?
  • Thread starter Thread starter elcaro
    Programming
The discussion centers on the concept of Intentional Programming and its effectiveness in software development. There is a noted similarity between Intentional Programming and Domain Specific Languages (DSL), as both aim to enable concise expression for specific problem domains. The conversation also touches on the tendency in software development for ideas to be rehashed or rediscovered over time. A distinction is made between intentional coding, where every piece of production code serves a clear purpose, and unintentional coding, where code is created through trial and error without a full understanding of the system. The notion that unintentional code can eventually yield valid results is mentioned, albeit with skepticism about the efficiency of such an approach. Overall, the dialogue reflects on the balance between intentionality and experimentation in programming practices.
elcaro
TL;DR Summary
Almost all existing programming languages work at the basis of source files (text format) that gets compiled/linked into executable code or interpreted. A different approach (such as utilized by Intentional Pogramming) stores program source not in text format but in its abstract syntax tree (AST). The approach here is similar to how relational databases work, avoiding redundancy. For example objects are identified by some key, while their names are just labels stored at only one place.
Has the approach towards programming, like for instance that of Intentional Programming, been proven to be fruitfull?
Technology news on Phys.org
I was not familiar with the specific concept of Intentional Programming before you mentioned it, but at a glance it seems to me that there is some overlap with the concept or pattern of Domain Specific Langauge in that both allow programmers to express themselves in way that is concise for a particular problem domain. I am not aware if any such overlap is accidentally or if part of IP went on to influence DSL (which seems a bit younger than IP). At least its quite common in the software business to see some of the same ideas being rehashed or rediscovered in quite many different incarnations over time.
Likes elcaro and jedishrfu
I favor the unintentional school of programming where one writes code not fully understanding the application or system and hopes not to make unintentional errors.
  • Haha
Likes berkeman and Filip Larsen
jedishrfu said:
I favor the unintentional school of programming ...
I actually first thought OP was thinking about the principle of intentional code, i.e. that all pieces of (production) code present should be there for a known and valid reason and not just because you hit it with a hammer (e.g. trial and error) until it magically worked. The hammer is reserved for experimental code only.
Normally code is written by monkeys, but you need a whole bunch of them and lot of time, before some unintentional valid code emerges...
Thread 'Star maps using Blender'
Blender just recently dropped a new version, 4.5(with 5.0 on the horizon), and within it was a new feature for which I immediately thought of a use for. The new feature was a .csv importer for Geometry nodes. Geometry nodes are a method of modelling that uses a node tree to create 3D models which offers more flexibility than straight modeling does. The .csv importer node allows you to bring in a .csv file and use the data in it to control aspects of your model. So for example, if you...
I tried a web search "the loss of programming ", and found an article saying that all aspects of writing, developing, and testing software programs will one day all be handled through artificial intelligence. One must wonder then, who is responsible. WHO is responsible for any problems, bugs, deficiencies, or whatever malfunctions which the programs make their users endure? Things may work wrong however the "wrong" happens. AI needs to fix the problems for the users. Any way to...
I am trying to run an .ipynb file and have installed Miniconda as well as created an environment as such -conda create -n <env_name> python=3.7 ipykernel jupyter I am assuming this is successful as I can activate this environment via the anaconda prompt and following command -conda activate <env_name> Then I downloaded and installed VS code and I am trying to edit an .ipynb file. I want to select a kernel, via VS Code but when I press the button on the upper right corner I am greeted...
