What's the acceleration of the 2kg block?
In summary, the conversation discusses a scenario involving a horizontal pulley with two attached blocks of different masses. The lower block is pulled by a rope with a tension force of 20N, and the coefficient of kinetic friction between the lower block and the surface is 0.30. The coefficient between the lower and upper block is also 0.30. The conversation explores the relationship between the acceleration of the two blocks and discusses the equations involved in determining this relationship.
bodensee9
178
Hello:
A picture is attached. I have 2 blocks that are attached to a horizontal pulley. One block (of 1Kg mass) is lying on top of another (of 2kg mass), and both are attached to two ends of the pulley (see attachment). The lower block is pulled by a rope with a tension force of 20N. The coefficient of kinetic friction between the lower block and the surface is 0.30. The coefficient between the lower and upper block is also 0.30. What's the acceleration of the 2kg block?
Wouldn't we have to find out if the first block will slip or not? So then friction max = 9.8*1*0.3 = 2.94, which gives an acceleration max of only 2.94. So if we pulled with 20N - friction on lower block, we have 14.12, we could still make the top block slip. I think the top box will need to slip, because if it didn't, then the friction would need to be greater than tension, meaning that the maximum tension would be equal to the maximum of friction, or 2.94. So 20 - friction on lower block - 2.94 = 11.18, which would accelerate the lower by
5.59 m/s^2. Seems odd to me. I'm not sure how to determine the relationship between thee acceleration of the lower and upper blocks.
The equations are:
T - 1.0*9.8*0.3 = 1.0*a.
20 - 2.0*9.8*0.3 - T = 2.0*(a of the lower box).
Thanks.
  • pulley.pdf
acceleration of top and bottom is the same since the strings length is constant.
For the lower box the bottom friction is mg*Mu note m is not 2 and then there's also the friction on the top.
so you are assuming that the top block isn't sliding?
Thanks.
The top is sliding, but the first equation seems right.
so the mass would be box 1 + box 2, or 3 then? I thought that only happens if the top box isn't sliding. thanks.
3 since it is also contributing to the normal force on the ground.
FAQ: What's the acceleration of the 2kg block?
What is acceleration?
Acceleration is the rate of change of velocity over time. It is a vector quantity, meaning it has both magnitude (speed) and direction.
How is acceleration calculated?
Acceleration is calculated by dividing the change in velocity by the change in time. The formula for acceleration is a = (vf - vi) / t, where a is acceleration, vf is final velocity, vi is initial velocity, and t is time.
What units is acceleration measured in?
Acceleration is measured in meters per second squared (m/s²) in the International System of Units (SI).
What does a negative acceleration mean?
A negative acceleration, also known as deceleration, means that an object's velocity is decreasing over time. This can happen if an object is slowing down or changing direction.
How does mass affect acceleration?
According to Newton's Second Law of Motion, the acceleration of an object is directly proportional to the net force acting on it and inversely proportional to its mass. This means that the greater the mass of an object, the smaller its acceleration will be for a given force.
