What's the car's acceleration at a specific point?
In summary,The car should increase its velocity by 0.8 m/s per each second (for a constant value of acceleration).
Northern Cardinal
A remote controlled toy car starts from rest and begins to accelerate in a straight line. The figure below represents "snapshots" of the car's position at equal 0.5 s time intervals. (Assume the positive direction is to the right. Indicate the direction with the sign of your answer.)
Using data from t = 0.5 s to t = 1.5 s, what is the car's acceleration at t = 1.0 s?
I know that change in velocity/change in time is used for average acceleration, but I'm not sure what to use for a specific point.
I did (0.9-0.1)/(1.5-0.5) = 0.8/1 --> 0.8 m/s^2
This doesn't look right to me. Is this actually correct or do I need to solve the problem a different way?
Welcome, Northern Cardinal! :cool:
Please, see:
http://hyperphysics.phy-astr.gsu.edu/hbase/acca.html
You could verify your answer, knowing that the car should increase its velocity by ##0.8~m/s## per each second (for a constant value of acceleration).
What should it be at 1 second, what at 2 seconds, if your answer is correct?
It helps to use units throughout.
What units would you get from (0.9-0.1)m/(1.5-0.5)s?
Likes etotheipi and Lnewqban
I realized I made a mistake when typing out what I did, I meant to just put 0.8 m/s. I still don't understand what to do with this however.
Likes Lnewqban
Perhaps if you make two graphs (distance versus time and velocity versus time) you could see how these parameters change.
The first one will give you a curve, with the values of instantaneous velocities for each point.
The second one will be a straight line, which slope is the constant acceleration of the car.
Please, see:
http://hyperphysics.phy-astr.gsu.edu/hbase/Mechanics/motgraph.html#c1
For each position of the car in the OP's schematic, there is only one value of instantaneous velocity.
The velocity of the car varies constantly with time, at a constant rate, which is the value of the acceleration you need to calculate.
I'm not entirely sure that I did this right, but I got 0.4 m/s^2. Is this correct?
Do you know how to use a spreadsheet, like Excel?
That is correct. :smile:
Could you show us what you did?
It is important that you understand, because future problems will be based on these concepts.
Are you sure about that?
I was, ...until now :confused:
Perhaps we need to check that the problem has been correctly posed. It asks for the acceleration at ##t = 1s##, but the data fits a constant acceleration profile. Should the question be: what is the velocity at ##t = 1s##?
@Northern Cardinal can you confirm?
I'm pretty sure the question is asking for the car's acceleration at t = 1s. The answer box on the website has "m/s^2" following it.
Okay. ##a = 0.4 m/s^2## is not right. If I use ##s = \frac 1 2 a t^2## with ##a = 0.4 m/s^2## and ##t = 2s## I get ##s = 0.8m##, which is not the car's displacement at ##t = 2s##.
Why didn't you check your answer like that? What stopped you plugging in your suggested answer to see whether it was correct?
I just started learning physics last week, this was our second real assignment. I hadn't learned how to check my work yet.
How should I do the problem instead?
Technology is your friend. In addition to calculators, you can do a lot of things on a spreadsheet; and, as you get more advanced by using computer programs or sophisticated mathematical packages. That said, I find you can do a lot in Excel to get you started.
The point is: whether you use a computer, calculator or pen and paper, you can calculate these values in each case for your suggested answer. And this is what you should be doing. The more calculations you do the better you understand what happens when you use these SUVAT equations.
I have to say I find this problem slightly confusing. The data is clearly (from experience) a constant acceleration motion. So, I don't know why you would use the data from ##0.5s## to ##1.5s## specifically. Either:
$$0.1m = \frac 1 2 a (0.5s)^2 \ \ \text{or} \ \ 0.4m = \frac 1 2 a (1s)^2$$
Would give you the value of ##a##, which you can then double-check for ##t = 1s## and ##t = 2s##.
Note that ##a## is constant here, but the velocity is changing with time.
Alright, thank you for your help!
In principle, this is a curve-fitting problem. You have three data points that you are using to fit a quadratic equation.
There are three unknowns in a quadratic equation (the "a", "b" and "c" in f(x) = ax^2 + bx + c). There are three data points that you have been asked to use (0.5, 0.1), (1.0, 0.4) and (1.5, 0.9). That's three constraints. The solution can be expected to be uniquely defined.
Lagrange interpolation is one "crank and grind" approach that could be used for this if physical intuition is not helping.
But you asked for advice on checking your work. The way you check your work is to write down that quadratic equation, possibly in the SUVAT form: ##s(t) = s_0 + v_0 t + \frac{1}{2} a t^2##.
[Be careful. Even though you also have a data point for t=0, there is no guarantee that your curve through the data points at t=0.5, 1.0 and 1.5 will hit it]
Plug in the time values for your data points (0.5, 1.0 and 1.5) and see if the "s" values (0.1, 0.4 and 0.9) match up.
Related to What's the car's acceleration at a specific point?
1. What is acceleration?
Acceleration is the rate of change of an object's velocity over time. It is a measure of how much an object's speed is increasing or decreasing.
2. How is acceleration calculated?
Acceleration is calculated by dividing the change in an object's velocity by the change in time. The formula for acceleration is: a = (v2 - v1) / (t2 - t1), where a is acceleration, v1 and v2 are the initial and final velocities, and t1 and t2 are the initial and final times.
3. What is the unit of acceleration?
The unit of acceleration is meters per second squared (m/s²) in the metric system and feet per second squared (ft/s²) in the imperial system.
4. How is acceleration related to force?
According to Newton's second law of motion, acceleration is directly proportional to the net force acting on an object and inversely proportional to the object's mass. This means that a greater force will result in a greater acceleration, while a larger mass will result in a smaller acceleration.
5. Can acceleration be negative?
Yes, acceleration can be negative. This means that an object's velocity is decreasing over time, either due to a decrease in speed or a change in direction. Negative acceleration is also known as deceleration or retardation.
12K
