Shardul Khare
- 23
Can somebody pls explain this to me?
What part didn't you get?Shardul Khare said:I didnt get it :(
emdezla said:However, given that the normal force is a contact force, what would be the force opposed to weight in the case of free fall?
emdezla said:As far as I've understood from my physics lectures, the normal force is a contact force which arises as a reaction of another force (third Newton's law)
emdezla said:For example, in the case of weight, the Earth exerts a force (mg) on us and so we exert a force on the Earth (i.e. the normal force).
You do realize that this thread is over 2 1/2 years old, and the OP hasn't visited Physics Forums for about 2 years, right? I'm closing this thread.Adesh said:I think this discussion may help I Derivation of the change of air pressure with height
A contact force is a type of force that results from direct physical contact between two objects. It can either be a push or a pull, and it can only occur when two objects are in contact with each other.
The normal force is a type of contact force that acts perpendicular to the surface of an object. It is the force that prevents objects from passing through each other and is often referred to as the support force.
The main difference between contact force and normal force is the direction in which they act. Contact force can act in any direction, while the normal force always acts perpendicular to the surface of an object.
Contact force and normal force can both change an object's motion. Contact force can either accelerate or decelerate an object, while the normal force can support an object's weight and determine its stability.
No, contact force and normal force are always present together in a contact situation. The normal force is a reaction to the contact force, and without the normal force, the contact force would cause objects to pass through each other.
