What's the energy-spread of the quantum Universe state?
In summary, the conversation discusses the concept of energy eigenstates and their implications for the dynamic behavior of the universe. It also touches on the role of entropy in the evolution of the universe and the application of quantum mechanics to systems that were not prepared in a laboratory setting. The participants also explore the idea of superposition and its relationship to energy eigenstates. Ultimately, the conversation highlights the fundamental role of quantum mechanics in understanding the behavior of the universe.
  • #36
PeroK said:
If you take the hydrogen atom in an energy eigenstate, that does not mean that the electron"is not moving". It means the atom has a defined energy: every measurement of energy returns the same value. The electron, when measured, has a non-zero kinetic energy.
If you try to extend the concept of motion - in the model of the solar system, for example - to an atom, the numbers and equations simply do not make sense. You could argue that at the quantum level the concept of motion no longer makes sense.
Motion at the macroscopic level is fundamentally a concept that arises when the quantum mechanical behaviour of a large number of particles is statistically amalgamated.
If you are studying QM and you are thinking in terms of classical motion, you are off on the wrong foot altogether.
By motion I mean that for some observable operator A then d<A>/dt is non zero.
For an energy eigenstate, all observables have d<A>/dt=0. That is what I mean by no motion.
Clearly the state of the Universe has d<A>/dt not =0. Hence it is not in an energy eigenstate.
  • #37
In your example of the hydrogen energy eigenstate, for all observables A,B,C etc
d<A>/dt=0, etc.
Nothing is in motion
  • #38
Robert Shaw said:
1) Universe is a closed quantum system
2) there is motion in the universe
I can accept 1 - but it may or may not be true - eg see the latest theories of continuous inflation.
I think what you mean by 2 needs clarification. Assuming you can give a meaning to the quantum state of the universe (many into quantum cosmology adhere to many worlds for this reason - you can do it in that interpretation) I am not sure what you mean by motion. If you mean Schrodinger's equation applies - sure - but beyond that I am a bit perplexed.
Thanks
Bill
  • #39
This is where we came in! You're still using the expected value - a statistical value - and confusing it with a single measurement.
There is nothing clear about your claims - they are simply a mixture of classical and quantum thinking and a fundamental confusion over the meaning of ##\langle A \rangle##.
The only thing that is clear is that there is no convincing you.
  • #40
d<A>/dt=0, etc.
And, yet, if you measure the electron it has a non-zero kinetic energy. How can something that is not moving have non-zero Kinetic Energy and non-zero Angular Momentum?
The fact that those values don't change over time has more of an analogy with the electron is not accelerating!
  • #41
I don't even get that - yes given a state and an observable you can predict an average - but without actual measurement, observation etc, its hard to understand its significance.
Hopefully he is referring to Schrodinger's equation which if you have an interpretation like Many Worlds is perfectly OK to discuss, and generally that's what those into quantum cosmology seem to favor. But we have more recent theories such as continuous inflation where perhaps you don't need MW, but this is not my area of expertise and I would like someone more familiar with it than me to comment.
Thanks
Bill
  • #42
Thanks
Bill
MWI or not, if you measure the kinetic energy of the moon at different times, then that gives you ##\frac{dA}{dt}##. It does not give you ##\frac{d\langle A \rangle}{dt}##.
The OP simply adds the expectation notation to mistakenly align classical thinking and calculations with QM.
Take some classical observable, add some angled brackets and you have QM. That's about the extent of it.
  • #43
Would you consider the moon a wavepacket of very small variance?
In practice of course you are correct - our current technology does not allow us to detect quantum effects with an object the size of the moon - no issue with that at all - but as a matter of principle I am not quite so sure.
Thanks
Bill
Likes Robert Shaw
  • #44
Thanks
Bill
So, what's your definition of ##\langle A \rangle##?
Are you also defining this as a single measurement?
Or the expected value of a set of measurements taken on a large number of identically prepared systems. Which is my definition.
  • #45
PeroK said:
So, what's your definition of ##\langle A \rangle##? Are you also defining this as a single measurement? Or the expected value of a set of measurements taken on a large number of identically prepared systems. Which is my definition.
<A> is the average of a number of measurements so large for all practical purposes it can be considered infinite.
However for the moon our measurement technology is not good enough to have any difference between measurements.
But I now see your point - you were not referring to A as an observable - which is what I thought you meant - you are referring to the actual measurement itself in which case your point is trivially true.
Thanks
Bill
Likes Robert Shaw
  • #46
Returning to my original question:
Please would you clarify do you think a closed Universe is in an energy eigenstate?
To reduce the problem to something simple and analytically solvable, let's treat the Universe as a two qubit closed system where there is an interaction. For any partial measurement to be non-static (e.g. the energy of particle 1) the total state cannot be in a single energy eigenstate.
Single observations are out of scope as QM can say nothing whatever about them.
  • #47
Thanks
Bill
My question is about how small is the variance.
While you may perhaps be right that it very small, I'm interested to understand the scale of "very small" and what factors contribute to its size.
  • #48
This is false. Write the total Hamiltonian schematically as ##H = H_1 + H_2 + H_i##, where ##H_1## is the free particle Hamiltonian of particle 1, ##H_2## is the free particle Hamiltonian of particle 2, and ##H_i## is the interaction Hamiltonian. If the system is closed, it will be in an eigenstate of ##H## (but see below for a caveat to this), but it will not, in general, be in an eigenstate of ##H_1## or ##H_2##. That means that measurements of the energies of the individual particles can give changing values, because those are measurements of ##H_1## or ##H_2##. (Heuristically, this is because the interaction creates a potential energy between the two particles, whose value is not contained in measurements of the energies of the individual particles.) But a measurement of ##H## will always give the same value.
Of course in this simple closed system, we can imagine measuring ##H##, because we know the real universe consists of a lot more than a closed two-qubit system. But if that closed two-qubit system were the entire universe, there would be no way to measure ##H##, because that would require the system to interact with something outside it. So there would be no way to test the claim that the system as a whole was, or was not, in an eigenstate of ##H##. However, if you try, you will see that it is impossible to write down a consistent state for the closed two-qubit system that is not an eigenstate of ##H##. Heuristically, this is because the system is closed and can't interact with anything else, so there is nowhere for it to gain or lose energy to. Any real system that is not in an energy eigenstate is not closed; it is interacting with something else (for example, an electron in an atom interacts with the electromagnetic field, which is what allows it to change energy levels).
  • #49
Robert Shaw said:
For any state to manifest motion, there must be a mixture of energy eigenstates (energy eigenstates are by definition stationary).
From this it follows that the state of the Universe is a superposition of energy states. I'd like to restrict the discussion by assuming the total state begins in a pure state.
So the interesting question is whether the width of the energy variance has any physical significance.
This is an answer that might be solvable for the very early universe, but it's also trivial and not very interesting (at least for simpler models):
The very early universe was in thermal equilibrium, which would indicate that the spread of energy eigenstates would have been drawn from the spread determined by the sum of energy of individual particles which follow the thermal distribution.
After stars and galaxies started to form, however, the question becomes much harder to answer. With matter no longer in thermal equilibrium, there aren't any simple calculations that can be done, and quantum gravity might have some influence on the result anyway.
As for the spread of energy states having any physical significance, I don't see how.
  • #50
Most states can all have interactions internally. All that's required is a Hamiltonian with off diagonal terms (and Hermitian). A simple example is a precessing qubit state. It isn't in a single energy state which is why it precesses.
The the two qubit case is interesting because solutions can be found where the energy oscillates between the two internal components with no energy flowing elsewhere.
An isolated harmonic oscillator has solutions that superpositions of energy levels (most textbooks cover this case).
An isolated atom can be in a superposition of energy states. It just sits in this superposed state, neither gaining nor losing energy.
For an isolated atom with spin-orbit coupling there are precessing solutions that are not energy eigenstates (this case can be found in many textbooks).
More complex versions crop up in quantum optics in connection with Glauber states and they certainly can be closed states.
So it is not correct to say "Any real system that is not in an energy eigenstate is not closed"
  • #51
It precesses because it's in an external field. In other words, the full state is not just the state of the qubit, but the state of the qubit and the state of the field. And the full Hamiltonian is not just the Hamiltonian of the qubit, but the Hamiltonian of the qubit plus the Hamiltonian of the field plus the interaction between them. The qubit's state is not an eigenstate of the qubit-only Hamiltonian, but the full state of the system (qubit and field) is an eigenstate of the full Hamiltonian. And it's the latter that is analogous to the state of the universe as a whole, since the universe as a whole has nothing else outside it to interact with.
Do you have a reference?
A harmonic oscillator does. An isolated harmonic oscillator doesn't, at least not in any meaningful sense; you can mathematically write down a superposition of its energy eigenstates, but energy will not be conserved in such a system, so it's not physically possible.
No, it doesn't. A superposition of energy eigenstates will change with time, and so will the probabilities of measuring it to be in different energy eigenstates if its energy is measured. Also see above.
They are not eigenstates of the Hamiltonian for just the electron. They are eigenstates of the full Hamiltonian of the entire atom, including the interaction between the electron and the nucleus. See above. (Technically, the full Hamiltonian would include the electromagnetic field, since that's what actually mediates the interaction between the electron and the nucleus; but for most purposes the approximation in which the Coulomb potential of the nucleus stands in for the EM field works fine.)
I'm not sure what you mean. A quantum optics system is never "closed" in the sense of being isolated; there are all kinds of devices in the system (beam splitters, etc.) whose states are not captured in the quantum state of the qubits.
Likes QuantumQuest
  • #52
I don't know if that's a valid conclusion.
There is no definite energy for a harmonic energy in a superposition of states. The expectation value of the energy is well-defined and changes over time, but the expectation value of energy isn't a conserved quantity. The change over time of the expectation value of energy will obey the time-energy uncertainty relation.
  • #53
Yes, I agree. Mathematically, that's what the expression for the state and operating on it with the Hamiltonian says. My point is not that you can't write down the math. My point is that the math doesn't describe anything that is physically possible; a fully isolated harmonic oscillator can't exchange energy with anything, so energy would not be conserved if it were not in an energy eigenstate. I don't think you can get around energy conservation just by saying that the energy of a non-eigenstate isn't well-defined, if that state represents an entire isolated system. In cases where an actual physical system is in a superposition of energy eigenstates, it's because it isn't isolated; there is an interaction with something else.
  • #54
The state only has to obey:
ih d|state>/dt = H |state> where H is the Hamiltonian for a closed state.
This does not imply that the only solution is an energy eigenstate. Superpositions are also solutions.
For example a wave packet is a multi-energy superposition of plane-wave energy eigenstates. It obeys the above equation.
If you believe otherwise, please would you show how the equation above leads to your conclusion. Begin by showing for wave packets.
  • #55
Mathematically, yes, as I have already said in response to @kimbyd. Math is not the same as physics. Physically, I do not think these solutions are reasonable for closed systems, for reasons I have already explained.
  • #56
I think you're mixing up classical and quantum concepts.
Ignoring the complexities introduced by gravity for a moment, a classical, closed system will have ##dE/dt = 0##. But quantum-mechanically, the value ##E## does not exist. You have energy eigenvalues, and an expectation value. The expectation value is not a physical quantity, and cannot be conserved. I'm pretty sure it's possible to prove that the expectation value of energy must be periodic, but there is no "E" to be conserved in the first place.
  • #57
There is if the entire closed system is in an eigenstate of the full Hamiltonian; then ##E## is just the eigenvalue. And my physical (not mathematical) argument is that only such states are reasonable for modeling entire closed systems like the universe. Yes, mathematically you can write down a state for the full closed system that is not an eigenstate of the full Hamiltonian; but does that make sense physically? I am arguing that it doesn't.
  • #58
I don't think you have a solid argument here.
Fundamentally, the universe is mathematical. Physical intuition can only get you so far. Much about the universe is extremely unintuitive. If you want to prove your position, you're going to have to show the math that demonstrates a cyclical closed system is unphysical.
That math would probably have be rooted in Noether's theorem, but I'm pretty darned sure that a quantum system in a mixed energy state fully complies with Noether's theorem as long as you do the calculations properly (i.e., don't attempt to impose a classical notion of energy onto the system).
  • #59
At this point we're out of physics and into speculation which is off topic for this discussion.
Noether's Theorem isn't about the state, it's about the Lagrangian. If the Lagrangian has a continuous symmetry, there will be an associated conserved current. It's a mathematical theorem; a system can't not "comply" with it (except in the trivial sense of a system whose Lagrangian has no continuous symmetries).
None of this has anything to do with the argument I was making.
  • #60
It does, because it means an isolated quantum system in a mixed state conserves energy.
  • #61
How can an isolated quantum system be in a mixed state? Again, I understand that you can write down such a state mathematically. But how does it make sense physically?
  • #62
Ok let's take the simplest quantum Hamiltonian, zero potential energy everywhere.
Then form a wavepacket.
Wavepackets can exist in isolated closed systems.
Yet they are superpositions of energy levels
  • #63
Reality is too complex for physics to model.
Football, a game of football, obeys the laws of physics. Physicists cannot model it however, not quantum nor classical.
Knowledge is the problem. We don't know enough about almost everything to write equations.
Look around you. Mostly complex molecules. Air is mostly molecules.
That's for engineers who do a great job using approximations of physics.
  • #64
Closed systems are idealisations.
Reality seldom approximates to a closed system.
On rare occasions real systems can be created that approximate to an idealised closed system.
Our knowledge of such systems is from the mathematics of the idealised closed system, for which we can write down equations.
Quantum physics textbooks are mostly concerned with closed systems. They tend to focus on eigenstates because they are mathematically simple and good for teaching purposes. They say a little about superpositions - the wavepacket, the Gaussian superposition of oscillator states, etc. but these are more difficult mathematically so get limited coverage.
  • #65
Why don't you write it all in ONE post? There is edit button.
  • #66
@Robert Shaw you are simply repeating your position without responding to what anyone else has said. That is not going to lead to a productive discussion.
Thread closed.
Likes weirdoguy and PeroK
