What's the error in my solution (Freight car and hopper)
In summary: Well, you can solve it, it just makes the problem messier. In the end, you get the same answer as the textbook's method.In summary, the conversation discusses an error in a student's solution to a physics problem involving a freight car, sand, and a constant force. The student's method does not take into account that each element of added mass must be brought up to speed, and their equation, $$M \frac{d v}{d t}=F$$ is incorrect as it only applies when M is constant. The proper way to solve the problem is to use the product rule when finding ##\frac {d(Mv)}{dt}## as both M and v are functions of time.
yucheng
232
57
An empty freight car of mass ##M## starts from rest under an applied force ##F##. At the same time, sand begins to run into the car at a steady rate ##b## from a hopper at rest along the track. Find the speed when a mass of sand ##m## has been transferred.
(Kleppner, 2nd edition, problem 4.11)
N/A
Textbook solution:
##v## is the instantaneous velocity,
$$P(t)=(M+b t) v$$
Then $$impulse = \Delta P = (M+b t) v = \int^{t}_{0} F dt'$$
Thus $$v=\frac{F t}{(M + bt)}$$
What I did instead was:
Let ##M## be the instantaneous mass, and ##M_0## be the initial mass, then $$M=M_{0} + b t$$
\begin{align*}
M \frac{d v}{d t}&=F \\
(M_{0} + b t) d v &= F d t \\
d v &= \frac{F}{(M_{0} + b t)} d t\\
\int^{v}_{0} d v' &= \int^{t}_{0} \frac{F}{(M_{0} + b t')} d t'\\
v &= \frac{F}{b}\ln{\frac{M_0 + b t}{M_0}} \\
\end{align*}
I would really appreciate it if you could point out where my conceptual error is. Do bear in mind that I have a huge tendency to just blindly manipulate equations :) I know, I'll have to overcome it. Thanks in advance!
Likes Delta2
yucheng said:
Homework Statement:: An empty freight car of mass ##M## starts from rest under an applied force ##F##. At the same time, sand begins to run into the car at a steady rate ##b## from a hopper at rest along the track. Find the speed when a mass of sand ##m## has been transferred.
Relevant Equations:: N/A
Textbook solution:
$$P(t)=(M+b t) v$$
\begin{align*}
\end{align*}
Your method does not take into account that each element of added mass has to be brought to speed v.
Honestly, I am very confused with the integrals. Would you explain more?
Your formula$$M \frac{d v}{d t}=F$$ is wrong. It only applies when M is constant
Use the product rule when finding ##\frac {d(Mv)}{dt}## as both M and v are functions of time.
Likes carx207 and yucheng
Although that works here, I have a distaste for writing ##\frac{dp}{dt}=m\frac{dv}{dt}+v\frac{dm}{dt}##, and I'm not alone.
At this level of physics at least, mass is neither created nor destroyed, so if ##\dot m## is nonzero we are not looking at a closed system. Mass is entering or leaving the system, and it could be taking momentum away with it or bringing momentum in.
You get away with it in this question because the sand had no horizontal velocity before being added to the load. A student applying the same equation to sand being dropped by a moving cart can go astray.
Likes Lnewqban
Suppose the wagon were merely kept going at constant velocity, your equation says that would take no force, but the added sand will increase the momentum of the wagon+load system. As each grain of sand is added, it takes an impulse to get it up to speed.
Likes Lnewqban
Hmm, looking back at my equation, it seems that it tells me for each instantaneous mass, the force causes an acceleration proportional to the mass. It is wrong because I am assuming that ##M+\Delta m##, where ##\Delta m## is the mass of the newly added sand, already has velocity ##v##, and then the equation holds true (since it is acceleration of the whole system, but since the sand added and the wagon have different speeds, they can't be considered as a homogeneous body?), while in fact it starts from rest. Is this what you meant?
$$M\frac{d v}{d t} + v \frac{d M}{d t} = F$$ looks impossible to solve!
Since ##\frac{d M}{d t} = b## is constant, $$M\frac{d v}{d t} + v b= F$$
It's not as bad as it looks. You can write down M as a function of t.
Likes yucheng
Let me try to continue.
$$(M+b t)\frac{d v}{d t} + v b= F$$
My first instinct is to multiply everything out...
$$(M+b t)d v + v b dt= F dt$$
$$(M+b t)d v = (F - v b) dt$$
$$\frac{1}{(F - v b)}d v = \frac{1}{(M+b t)} dt$$
$$v = \frac{Ft}{M+bt}$$
Okay, it works, thanks!
Likes Lnewqban and Steve4Physics
I think that the equation itself is OK because it follows from the product rule of differentiation. Problems arise when folks misuse it. One must keep in mind that the generalized form of Newton's second law is ##\vec F_{\text{Net}}=\frac{d\vec P}{dt}## and that, to use it correctly, one must assemble the LHS first and then set it equal to the RHS. This avoids the pitfall of treating ##m\dot v## or ##v\dot m## as if they were external forces.
Likes hutchphd
Of course, but that happens so often.
There is no point in using that form, instead of F=ma, if we are only considering an external force on what is otherwise a closed system. So consider the case of two adjacent wagons traveling E at the same velocity. A worker on A is shovelling sand directly across (from the worker's perspective) to wagon B.
Wagon B is gaining momentum at steady velocity, so the arriving sand must constitute an external force on the system, even though it imparts no EW force where it lands.
Hardly surprising students get confused.
Likes Lnewqban
I concede. There is also no point in using a sledgehammer to kill a fly when a fly swatter will suffice.
Related to What's the error in my solution (Freight car and hopper)
1. What does "error in my solution" mean in the context of freight cars and hoppers?
In this context, "error in my solution" refers to a mistake or incorrect calculation in the process of loading and transporting freight cars and hoppers. It could be due to various factors such as incorrect weight calculations, improper loading techniques, or equipment malfunctions.
2. How can I identify the error in my solution for freight cars and hoppers?
The best way to identify the error in your solution is to carefully review and double-check all the calculations and procedures used in the loading and transportation process. You can also consult with other experts or use specialized equipment to detect any potential errors.
3. What are the consequences of having an error in my solution for freight cars and hoppers?
The consequences of an error in your solution can range from minor delays and inconveniences to serious accidents and damages. Incorrect weight calculations, for example, can lead to overloading and potential derailment of the train, while improper loading techniques can cause damage to the cargo and equipment. These errors can also result in financial losses and legal liabilities.
4. How can I prevent errors in my solution for freight cars and hoppers?
To prevent errors in your solution, it is essential to have a thorough understanding of the loading and transportation process and to follow all safety regulations and protocols. Regular maintenance and inspections of equipment are also crucial to ensure their proper functioning. Additionally, having a system in place for double-checking calculations and procedures can help catch any potential errors before they cause any problems.
5. Are there any resources available to help me with identifying and correcting errors in my solution for freight cars and hoppers?
Yes, there are various resources available, such as industry guidelines and standards, training programs, and expert consultations, that can help you identify and correct errors in your solution for freight cars and hoppers. It is also beneficial to stay updated on any advancements or changes in technology and techniques used in the industry to ensure the most accurate and efficient solutions.
