- #36
eaglelake
- 131
LostConjugate said:But then the particle states of which the waves are a superposition would need to be described in the position basis and once again would become a particle of waves. So the particle is a particle of waves of particles of waves of particles of waves...
Is it the chicken or the egg?
This is a common misconception - that somehow the particle is a wave, or a superposition of waves, This is not true! The fallacy occurs when we confuse the particle, which is a part of the experiment, with the state function, which is a mathematical thing that we use to determine probabilities. The state function is a probability amplitude defined in a linear function space. The state function does not describe the behavior of the particle as it traverses through the experimental apparatus. Nor does the state function propagate in 3-space, as the particle does. Particles interact with particle detectors, state functions do not. No experiment has ever revealed a state function moving along with the particle.
The quantum mechanical explanation of tunneling is thus: If the momentum state is an eigenstate of momentum, i.e. we have prepared particles with a known momentum, then there is an infinite uncertainty in the particles position. That means we have no idea where the particle will be found when we make a position measurement. The experimental results verify this. Position measurements find some particles in front of the barrier, while other measurements find it behind the barrier, as if it had somehow penetrated (tunneled?) through the barrier. But such a view is a classical picture that has no connection with the results of this experiment. All we know is that, in the tunneling experiment, some particles are found beyond the barrier, and with the state function, we can predict the probability of this happening. Neither quantum theory nor the actual experiment gives a mechanism for such behavior. There is no answer to the question, "how did the particle get beyond the barrier"? Quantum mechanics doesn't tell us, and we know classical mechanics doesn't work.
Best wishes
