Whats the name of this function?
  • Thread starter Thread starter granpa
    Function
The discussion centers on identifying a function related to an integral provided by Wolfram's site, specifically involving the Hypergeometric function 2F1. Users note that the integral of the function ((2.5e+9)*x^5.5)/(((1.25e+10)-x)*(1e55)) yields a result containing unfamiliar functions. One participant successfully computes a similar integral, resulting in standard functions like logarithms and polynomials, suggesting a change of variable could simplify the original integral. The conversation emphasizes the importance of input format for obtaining simpler results from computational tools. The thread concludes with a recommendation to adjust the variable to achieve a more straightforward outcome.
granpa
this site:
http://integrals.wolfram.com
gives the integral of this function:
but the answer contains some function I've never heard of before and can't find in the documentation.
it looks like 2F1 (6.5, 1; 7.5; 8.02014*10^-11x)
whats the name of this function?
Mathematics news on Phys.org
Well right at the bottom of the page that gives the anti-derivative, you have two links to the function named Hypergeometric2F1 (Hypergeometric Function).
Good site.
I just tried \int \frac{x^{11/2}}{1-x} and I got a result in terms of only standard functions (just log sqrt and polymonials).
Your integral can easily be put in the above form with a change of variable so I'm not sure why you got a Hypergeometric?BTW. The result I got was :
\frac{-2 \sqrt{x} \, (3465 + 1155 x + 693 x^2 + 495 x^3 + 385 x^4 + 315 x^5 )} {3465}\, - \, \log(-1 + \sqrt{x}) \,+\, \log(1 + \sqrt{x})Note that I entered your integral (or one trivially close to it) in the form that I thought would be least likely to confuse the program. I find that this is usually a good idea if you're hoping to get an answer in it's simplest form.
BTW. Just substitute x = 1.25E+10 u to put your itegral into the above form.
BTW: I just checked and it was only the 11/2 versus the 5.5 that was needed to give the simpler result.Also it seems that there's plenty of factors that cancel in the above.
-2 \sqrt{x} \, (1 \,+\, \frac{1}{3}\, x \,+\, \frac{1}{5}\, x^2 \,+\, \frac{1}{7}\, x^3 \, +\, \frac{1}{9}\, x^4 \, +\, \frac{1}{11} x^5 ) - \, \log(-1 + \sqrt{x}) \,+\, \log(1 + \sqrt{x})
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
