I What's the proof that R2 /(R+h) = (1 – 2h/R)
  • I
  • Thread starter Thread starter Karagoz
    Gravity Proof
The discussion centers on the derivation of the formula for acceleration due to gravity at height h, expressed as g1 = g (1 – 2h/R). The transition from R^2 /(R+h)^2 to 1/(1 + h/R)^2 involves dividing both the numerator and denominator by R^2. The assumption that h is much smaller than R allows for the simplification using a Taylor series expansion, retaining only the first term. This leads to the final expression of (1 – 2h/R). Understanding these steps clarifies the mathematical reasoning behind the derivation.
Karagoz
TL;DR Summary
When proving formula for acceleration due to gravity at height h – with derivation, there are some steps I don't understand.
Hi,
On this link: https://physicsteacher.in/2020/07/1...n-due-to-gravity-at-height-h-with-derivation/
They prove the formula for acceleration due to gravity at height h, which is: g1 = g (1 – 2h/R).
There are similar articles online.
When they go through the last steps, it shows something like this:
g1/g = R2 /(R+h)2
= 1/(1 + h/R)2 = (1 + h/R)-2 = (1 – 2h/R)
But I don't understand, how does one move from R^2 /(R+h)^2 to 1/(1 + h/R)^2 = (1 + h/R)^-2 and then to (1 – 2h/R)
Could someone explain what's happening there?
The first step is simply to divide both numerator and denominator by R^2. In the second step, they have assumed that h<<R, so h/R <<1. You can then do a Taylor series expansion and keep only the first term in h/R.
Likes Karagoz and berkeman
Consider an extremely long and perfectly calibrated scale. A car with a mass of 1000 kg is placed on it, and the scale registers this weight accurately. Now, suppose the car begins to move, reaching very high speeds. Neglecting air resistance and rolling friction, if the car attains, for example, a velocity of 500 km/h, will the scale still indicate a weight corresponding to 1000 kg, or will the measured value decrease as a result of the motion? In a second scenario, imagine a person with a...
Scalar and vector potentials in Coulomb gauge Assume Coulomb gauge so that $$\nabla \cdot \mathbf{A}=0.\tag{1}$$ The scalar potential ##\phi## is described by Poisson's equation $$\nabla^2 \phi = -\frac{\rho}{\varepsilon_0}\tag{2}$$ which has the instantaneous general solution given by $$\phi(\mathbf{r},t)=\frac{1}{4\pi\varepsilon_0}\int \frac{\rho(\mathbf{r}',t)}{|\mathbf{r}-\mathbf{r}'|}d^3r'.\tag{3}$$ In Coulomb gauge the vector potential ##\mathbf{A}## is given by...
Thread 'Does Poisson's equation hold due to vector potential cancellation?'
Imagine that two charged particles, with charge ##+q##, start at the origin and then move apart symmetrically on the ##+y## and ##-y## axes due to their electrostatic repulsion. The ##y##-component of the retarded Liénard-Wiechert vector potential at a point along the ##x##-axis due to the two charges is $$ \begin{eqnarray*} A_y&=&\frac{q\,[\dot{y}]_{\mathrm{ret}}}{4\pi\varepsilon_0 c^2[(x^2+y^2)^{1/2}+y\dot{y}/c]_{\mathrm{ret}}}\tag{1}\\...
