What's the terminal velocity of a Boeing 737 in free fall from 12.496km
In summary: Sure. I wouldn't have made... that kind of error in my native language.In summary, there is no specific terminal velocity for a Boeing 737 in free fall as it depends on the orientation of the aircraft, and it is unlikely for all engines to fail while the aircraft is at 12.496km in the air. Additionally, the concept of "free fall" and "terminal velocity" are mutually exclusive.
NovaBlast
Say that all the engines of a boeing 737 failed while it was 12.496km in the air and fell into freefall, what would its terminal velocity be and how long would it take to hit the ground
Welcome to the PF. :smile:
NovaBlast said:
Summary:: what's the terminal velocity of a boeing 737 in free fall after the engines have failed, from 12.496km, and how long would it take to hit the ground?
What do you mean by "freefall"? Flat spin? Nose down streamlined? Tumbling? What is your motivation for asking this question?
Likes russ_watters
And the oddly specific height?
Likes davenn
There’s no such thing - “free fall” and “terminal velocity” are mutually exclusive.
I expect that you actually had a different question in mind, namely what speed will the aircraft reach if placed in an unpowered vertical dive. I would not surprised to find that the airframe breaks up before that terminal speed is reached.
Likes davenn, etotheipi and russ_watters
And just in case the OP thinks that its the engines that keeps an aircraft flying, let me add that it is the wings (the lift generating device in general) that does that, that it is the wings that allows an aircraft to maintaining forward speed while not gaining too much downwards speed. The engines are simply put just there to provide convenient acceleration and overcome drag.
As an example, gliders are a type of aircraft that can fly completely without engines using uprising natural winds to maintain or gain altitude, capable of traveling thousand of kilometers conditions permitting.
Also, its not uncommon that even passenger jets, which are normally supposed to operate with their engines on at all times, can be glided to a (more or less) safe landing in case of engine outage.
Likes Lnewqban and russ_watters
The scenario isn't just odd, it is poorly defined and not physically realistic. Just having engines fail doesn't cause an airplane to fall in freefall, and the descent rate depends entirely on the orientation. E.G., is it gliding, diving or stalled?
And on the other side of the coin is Air France 447, which stalled, fell out of the sky and crashed with little forward speed and the engines at full throttle.
Air France 447 was an Airbus A330, a plane in about the same class as the 737. It fell in a powered stall from 38,000 feet (11.6 km) in about 4 minutes. That's an average vertical speed of 108 mph or about the terminal velocity of a skydiver.
Likes davenn and Lnewqban
Especially the 737.
Its just 41000 feet converted to km with improper truncation. That fits quite well to the overall quality of the question.
  • Haha
Likes DaveC426913, berkeman and russ_watters
41,000 feet happens to be the ceiling for late-model 737 aircraft, so I suspect that is where the oddly specific height came from. The rest... who knows.
Likes pbuk, hutchphd and berkeman
This is inevitable. However, I would be interested in the rocket that put the 36 tons up there. That's 50% above what a space shuttle could launch.
  • Haha
  • Skeptical
Likes atyy, davenn, pbuk and 2 others
fresh_42 said:
This is inevitable.
I think you have messed up a conversion somewhere. As @boneh3ad says, 12,497m = 41,000 feet which is the service ceiling for a (modern) 737.
Likes davenn
Yes, I got lost in translation, sorry. We use points to separate the three digit packages and commas as decimal separator.
Here's what happened when both engines failed on a 737-3T0 at about 16,500 feet during descent towards New Orleans in 1998. TL;DR it landed safely, no injuries.
Likes atyy, russ_watters and Lnewqban
Not in aviation we don't, such errors would be... unfortunate :biggrin:. Even a Lufthansa flight at that altitude would report flight level (FL) 410.
Sure. I wouldn't have made the mistake if it was 41,000 ft. But it was 12.946 km, which isn't used in aviation. I normally recognize it, but once in a while I slip, seduced by the imagination of a B737 in space.
Likes atyy and pbuk
Incidentally, that's not far off of what L. Ron Hubbard imagined.
The main points relevant to this have already been addressed by many other people, but as an airplane buff, I'd just like to point out that the 737 has a max takeoff weight of just under 200,000lb in its largest configuration, and can carry around 175 people 3000-3500 nautical miles or so. The A330 in its largest configuration is well over 500,000lb, with a max seating capacity over 400 people and a range of over 6000 nmi. I wouldn't really consider the two in the same class. Here's a picture showing both for comparison.
That having been said, both would behave pretty similarly in the case of a full stall, and both would also behave similarly in an engine out glide. As everyone has already said, engine failures have occurred more than once in aviation history, and generally it results in a relatively uneventful glide, though this does of course depend on there being a suitable landing location within gliding range.
Likes Nugatory, russ_watters and Lnewqban
I was on a flight once with an engine failure during take-off. The plane had just left the ground and was accelerating upwards pretty hard when we heard a loud bang and everyone sort of swayed forward as the acceleration reduced sharply. The flight was headed to West Palm Beach Florida, out of Hartford, Connecticut and half the passengers were Pratt & Whitney engineers: I could hear the diagnostic mumbling up and down the aisle, "... second stage framowitz..."
The passenger next to me asked "what was that" and I replied "engine failure." That's when she started screaming. I felt bad, I should have just shrugged. We circled back and landed without further issue.
  • Haha
Likes pbuk, atyy and berkeman
Carry a sharpie. Next time, when that happens, start writing on your arms. When she asks you what you are doing say "Writing my seat number on my limbs. It makes it easier for the investigators." Then you'll really hear screaming!
Never lost an engine on takeoff, but had an aborted landing once. Coming into FRA and I am looking out the window and thinking "Hmmm...I've never seen the Waldstadion look so clear" and then we wooshed up. A 777 is big, but it can move when it has to.
  • Haha
  • Wow
Likes gmax137, fresh_42, russ_watters and 1 other person
We got diverted to another airport due to "a problem at our destination airport". When we landed they told us that the problem with the original airport was that its runway was too short for our aircraft to land if its flaps won't deploy... I'd noticed surges of acceleration as we circled over the original airport, presumably as they throttled up to counteract the expected drag from the flaps.
The whole thing added about fifteen minutes to our flight, plus about an hour and a half on a bus to our original airport. That's when I developed a gut feel for how fast planes actually travel.
There was once an Indian B-747 who touched down too early and crashed the entire signal system.
What a luxury. I once landed in a Russian town 300 km away from the destination. They said something about the weather, but it was a clear day. They said that we will possibly fly the remaining rest in an hour or so. The plane was full of red cross personal and other NGO stuff headed to watch what the Russians would do in Chechnya. They must have heard me talking as I had been asked in German whether I was an observer, too. No, I said, I'm here for drinking. The point is, after an hour we saw that they had packed the baggage somewhere without noticing anyone. I was accompanied by a local so we grabbed our suitcases and booked a bus tour. I have no idea what had happened to all the others, presumably not speaking Russian. The bus was funny, too. We stopped somewhere in the middle of nowhere so that people could go for the toilet, which was into the bushes, and coming back to the bus, I saw that its lights were so dim, that I wondered whether we could be seen at all in the (meanwhile) dark. Plus I could read the advertisement on the side of the bus. It was in German. And it was not new.
It's not that often that you feel what full power at low weight is like, but yeah, when that happens, modern jetliners can really move. Especially on something long range like a 777, it can be lighter by a substantial fraction of its weight at landing just due to fuel burn during flight, so you normally don't get to feel acceleration under those conditions (and it's not uncommon to take off at below full power to decrease engine wear).
Likes russ_watters
russ_watters said:
The scenario isn't just odd, it is poorly defined and not physically realistic. Just having engines fail doesn't cause an airplane to fall in freefall, and the descent rate depends entirely on the orientation. E.G., is it gliding, diving or stalled?And on the other side of the coin is Air France 447, which stalled, fell out of the sky and crashed with little forward speed and the engines at full throttle.
Isn’t there a formula for terminal velocity gravity x acceleration x weight or something like that?
To calculate the terminal velocity we need to know the drag force from air resistance as a function of speed. Terminal velocity is that speed at which the drag force exactly counteracts the weight.
Arjan82 said:
Perhaps the question is related to this crash?:
https://www.bbc.com/news/business-61488976
Possibly, but the plane in that crash did not stay in the vertical dive all the way from altitude. It dove fairly far down, leveled off, and then did the final fatal dive.
In any case, this thread has run its course and will now be closed. Thanks to all who have participated.
Likes SammyS
FAQ: What's the terminal velocity of a Boeing 737 in free fall from 12.496km
1. What is terminal velocity?
Terminal velocity is the maximum speed that an object can reach while falling through a fluid, such as air or water. It occurs when the force of gravity pulling the object down is equal to the force of air resistance pushing against it.
2. How is terminal velocity calculated?
The formula for calculating terminal velocity is Vt = √(2mg/ρAC), where Vt is the terminal velocity, m is the mass of the object, g is the acceleration due to gravity, ρ is the density of the fluid, A is the cross-sectional area of the object, and C is the drag coefficient.
3. What factors affect the terminal velocity of an object?
The terminal velocity of an object is affected by its mass, surface area, and the density and viscosity of the fluid it is falling through. Objects with a larger surface area and lower density will have a lower terminal velocity, while objects with a smaller surface area and higher density will have a higher terminal velocity.
4. How does the altitude affect terminal velocity?
The altitude does not significantly affect the terminal velocity of an object in free fall, as long as the object is still within the Earth's atmosphere. However, at higher altitudes where the air is less dense, the object may experience a slightly higher terminal velocity due to decreased air resistance.
5. What is the terminal velocity of a Boeing 737 in free fall from 12.496km?
The terminal velocity of a Boeing 737 in free fall from 12.496km would depend on various factors such as the weight and size of the specific aircraft, as well as the air density and other environmental conditions. It is not possible to accurately determine the terminal velocity without more specific information.
