When adding up velocities, is it possible to produce 1+1=1?
  • Thread starter Duchovnik
In summary: In the case of two vectors with the same numerical value but different directions(i.e. the vectors are pointing in opposite directions), the resultant vector is always zero.
Duchovnik
Forgive me if the question sounds ignorant and petulant, but I am very curious about this and woefully undereducated in physics. I was browsing a debate board and the topic was whether or not logic is a human construct.
One of the arguments posited by someone was that everyone would logically deduce that 2+2=4, but that if you started adding up velocities under relativity you would get 1+1=1. I would just like to know if this is true or not.
It came from post #10 on this page:
http://www.4forums.com/political/worldviews/7480-how-do-atheists-account-laws-logic.html
Appreciate anyone's time, and thanks for reading.
It seems to me that the "1+1=1 according to Special Relativity" statement is true. Think of Einstein's example of someone shining a flashlight on a train moving at almost the speed of light. (For the latter, it'd be something like 1+0.99=1.) But, I'm just an amateur physics enthusiast. I'd be curious what an expert in SR would say.
Velocity addition is, of course, something of a misnomer. 1+1 still equals 2, but if the velocity of something is measured as u in one frame, then in a frame moving at v the velocity of that thing is (u+v)/(1+uv/c²). This is obviously only equal to u+v in the limit of uv<<c².
It would be more correct to call it "velocity composition" instead of "velocity addition" with the understanding that in Galilean relativity velocity composition is simple addition and in Special Relativity velocity composition is the more complicated expression given above.
In addition to the above velocity is a vector and in classical physics when two vectors of numerical value unity are added vectorially(taking directions into account)the resultant vector can have any numerical value between zero(when the vectors are in opposite directions and cancel) and two(when they are in the same direction and add)
FAQ: When adding up velocities, is it possible to produce 1+1=1?
What does the equation 1+1=1 mean in terms of adding velocities?
The equation 1+1=1 in terms of adding velocities means that when two velocities are added together, the resulting velocity is equal to the original velocity.
Is the equation 1+1=1 applicable to all types of velocities?
No, the equation 1+1=1 is only applicable to velocities that are measured in the same direction and have the same magnitude.
Why does adding velocities result in a sum that is equal to one of the velocities?
This is because velocities are vector quantities, meaning that they have both magnitude and direction. When two velocities are added, the resulting velocity is equal to the original velocity because the direction and magnitude of the two velocities cancel each other out.
Can the equation 1+1=1 be applied to other mathematical operations?
No, the equation 1+1=1 is specific to adding velocities and cannot be applied to other mathematical operations such as multiplication or division.
What is the practical application of understanding the equation 1+1=1 when adding velocities?
Understanding the equation 1+1=1 when adding velocities is important in many fields such as physics and engineering. It allows scientists and engineers to accurately calculate and predict the motion of objects, which is crucial in designing and building structures and machines.
