Daniel Hendriks
- 10
- 2
Is this known in QFT or is this "spontaneous".
A free electron emiting a photon is forbidden by conservation of energy.Daniel Hendriks said:Is this known in QFT or is this "spontaneous".
There is a matrix element for that transition which you can compute, and then calculate the decay rate (half life if you will). Note that this can not happen for a free electron, as pointed out in the previous post.Daniel Hendriks said:Can you explain "might"? This is what I want to know.
Processes in quantum mechanics are deterministically random. We can compute the probabilities, but we can not predict what will come out in the experiemnt. Compare with radioactivity (have you studied radioactivity in school?)Daniel Hendriks said:So it is on luck? Or maybe it is not known I conclude.
We know that the transition will happen, we know the average duration before many of these transitions will occur, we know how much energy will be released, and we know various other facts about the transitions, but if you're asking an underlying 'why' you may be disappointed. I could say that the transition occurs because it is energetically favorable, or that it occurs because the laws of nature allow it, and I'm sure there are various ways of explaining it using quantum mechanical and mathematical details involving fields and charges. Beyond that, you start running into an ever deeper series of 'why' questions that can't be answered and, even if they could, would just result in another 'why' question.Daniel Hendriks said:So it is on luck? Or maybe it is not known I conclude.
The first thing someone learning this stuff needs to know is the Schrodinger equation.Daniel Hendriks said:Thanks. What does energetically favorable mean? What is wrong with saying we only know the average and amount of energy, but we don't have a clue what is happening? That's the first thing someone learning this stuff needs to know.
Energetically favorable means that there is available energy that can be 'liberated' or 'moved' by the electron transitioning between a higher and lower energy level. In contrast, the transition of an electron from its ground state to a higher energy state isn't energetically favorable, as it would require that something add energy to the atom for this transition to happen.Daniel Hendriks said:Thanks. What does energetically favorable mean?
But we do have a clue as to what is happening, unless you subscribe to the belief that, since physics can't know absolute truths, we can't say we know anything about the universe. Which I would disagree with.Daniel Hendriks said:What is wrong with saying we only know the average and amount of energy, but we don't have a clue what is happening?
But it's a first step at understanding the math and models that we use to describe atoms and other quantum-scale systems, including photons.Daniel Hendriks said:The Schrödinger equation doesn't describe photons.
Daniel Hendriks said:You need to understand before you start learning something, what you are going to learn and what the limitations are. Thats the whole problem with schools, you start but nobody even the teacher knows anything. That's why the system is failing.
Are you suggesting that all teachers does not know anything? I mean they don't even know what date and time it is?Daniel Hendriks said:Thats the whole problem with schools, you start but nobody even the teacher knows anything.
Daniel Hendriks said:The Schrödinger equation doesn't describe photons. You need to understand before you start learning something, what you are going to learn and what the limitations are. Thats the whole problem with schools, you start but nobody even the teacher knows anything. That's why the system is failing.
This is nonsense. Please check your PMs.Daniel Hendriks said:The Schrödinger equation doesn't describe photons. You need to understand before you start learning something, what you are going to learn and what the limitations are. Thats the whole problem with schools, you start but nobody even the teacher knows anything. That's why the system is failing.
Electrons emit photons when they undergo a change in energy level. This can happen when they absorb energy from an external source, collide with other particles, or when they transition to a lower energy state.
An electron emits a photon because of the principles of quantum mechanics. According to the theory, electrons can only exist in certain energy levels and when they transition between these levels, they emit or absorb energy in the form of photons.
Electrons emit photons through a process called spontaneous emission. This occurs when an electron in an excited state spontaneously transitions to a lower energy state, releasing a photon in the process.
After emitting a photon, the electron transitions to a lower energy state. It can then remain in this state or absorb energy from an external source and transition back to a higher energy state, emitting another photon in the process.
Yes, an electron can emit multiple photons if it undergoes multiple energy level transitions. This can happen in a process called stimulated emission, where an incoming photon causes an already excited electron to emit another photon with the same energy and direction.
