When calculating a car's acceleration, is it ok to substitute Torque?
In summary, when calculating a car's acceleration, it is acceptable to substitute torque into the equation a = F/m as long as certain conditions are met, such as the angle between the radius and force vectors being 90 degrees. However, this equation is only valid for particle-like motion and may not accurately represent planar motion.
inv
46
" When calculating a car's acceleration, is it ok to substitute Torque into a= F/m "
a= F/m
T= Fr
1. When calculating a car's acceleration, is it ok to substitute Torque into a= F/ma= F/m
T= FrF= T/rwhere
a= acceleration,
F= force,
m= mass,
T= Torque,
r= radius,a= T/rm ?
What type of torque are you referring to?
Likes etotheipi
I think there is only one type of torque ; do you mean, where is this torque being measured?
I would also ask where this radius is being measured.
Likes etotheipi
I agree with @haruspex, it is tricky to say without more context. If we measure torques about some fixed coordinate system, and the car we model as a particle, then if the resultant force on the car is ##\vec{F}## we can write down ##\vec{F} = m\vec{a}## (or with magnitudes, ##F=ma##) in addition to ##\vec{\tau} = \vec{r} \times \vec{F}##. The latter also reduces to ##\tau = rF\sin{\theta}## if we take magnitudes.
Now if the angle ##\theta## between the ##\vec{r}## vector and the ##\vec{F}## vector is 90 degrees, then ##\tau = rF##, like you say. So if all these conditions are satisfied, ##\tau = rma## is I believe valid.
The condition that ##\vec{r}## always be orthogonal to ##\vec{F}## is the most restrictive one here. It means that your equation is fine for something like circular motion, but generally incorrect for most planar motion.
Likes Lnewqban
Related to When calculating a car's acceleration, is it ok to substitute Torque?
1. What is torque and how does it relate to a car's acceleration?
Torque is a measure of the rotational force applied to an object. In the context of a car's acceleration, torque is the force that causes the wheels to rotate and propel the car forward.
2. Why is torque important in calculating a car's acceleration?
Torque is an essential factor in determining a car's acceleration because it directly affects the car's ability to generate power and accelerate. The greater the torque, the faster a car can accelerate.
3. Can torque be substituted for other variables when calculating a car's acceleration?
Yes, torque can be substituted for other variables such as horsepower or force when calculating a car's acceleration. However, torque is the most direct and accurate measure of a car's ability to accelerate.
4. Are there any limitations to substituting torque in the calculation of a car's acceleration?
While torque is an important factor in calculating a car's acceleration, it is not the only factor. Other variables such as weight, aerodynamics, and friction also play a significant role in a car's acceleration and cannot be substituted by torque alone.
5. How can torque be measured and calculated in a car?
Torque can be measured using a dynamometer, which is a device that measures the torque and rotational speed of an engine. It can also be calculated using the formula torque = force x distance, where force is the amount of power applied and distance is the length of the lever arm.
