When can a charged sphere be treated as a point charge?
In summary, a charged sphere can be treated as a point charge when the charge distribution is spherically symmetric, meaning that the electric field outside the sphere is exactly the same as that created by a point charge at the center of the sphere. However, this only holds true when the sphere is isolated from other charges or objects. If there are external charges or objects nearby, the electric field will be distorted and the sphere can no longer be treated as a point charge. In these cases, more advanced methods must be used to model the electric field.
annms
Not much more to add to the title. I was just wondering, under what conditions can a charged sphere be treated as a point charge?
The electric field outside a (uniformly) charged sphere is equal to the electric field that would have been created by a point charge with the same total charge.
When the charge distribution is spherically symmetric, the field outside the sphere is exactly that of a point charge at the center of the sphere. (Where the charge of the point charge equals the total charge of the sphere.)
So in cases when the charge is uniformly distributed over its volume or its surface, the sphere can be treated as a point charge?
yep. Doc Al's response is slightly more accurate than mine - as long as the charge distribution is symmetric, the electric field outside will be same as that created by a point charge.
So any symmetric distribution you can think of will have this remarkable property.
Edit: For clarity, symmetric just means that the charge distribution will only depend on the radius. (Well, that's probably not the technical meaning of symmetric, but that's what it means in this example).
Apply the Gauss law in Maxwell's equations. Integral form, ∫E·dA=Q/ε0, where Q is the charge bounded inside the close surface. For any spherical Gaussian surface, E4πr2=Q/ε0, and is exactly the same as coulomb's law for point charge.
This means you can apply to whatever the charge distribution, it can be modeled by a equivalent point charge.
"When can a charged sphere be treated as a point charge? "
This is only true if the sphere is isolated from everything else. If another charge, or another object held at some potential, is brought near the sphere, it will induce surface charges in the sphere that are not spherically symmetric, and therefore you can no longer treat it as a point charge. But if the radius of the sphere is very small compared to characteristic lengths of the system, then you can treat it as a point charge even if it is not isolated because the induced charges will be spherically symmetric as an approximation if the sphere is very small.
But it can still be viewed as an point charge by taking a new gaussian surface where the centre shifts to the new equivalent point charge and take a larger sphere. Everywhere outside the surface the model is still valid.
But when there is an external charge the field is again distorted. Actually the net field should be modeled by another equivalent charge and a even larger sphere as gaussian surface.
I think you are confused. The Guassian-surface trick only works if you have a constant field over the Gaussian surface which will only happens if the charge density if there is symmetry (a spherical Gaussian surface requires a spherically symmetric charge density, a cylindrical Guassian surface requires...,etc). As soon as the symmetry is lost, the Guassian-surface trick no longer works and you have to go to more advanced methods (method of images, Green functions, etc).
No, no, no. Even if you shift the centre and use a larger gaussian sphere, the electric field at each point on that gaussian sphere would not be equal. (Because the distribution is no longer symmetric).
Related to When can a charged sphere be treated as a point charge?
1. What is a charged sphere?
A charged sphere is a physical object with a net electric charge, meaning it has more positive or negative charges than the opposite charge. This can occur naturally or through the addition or removal of electrons.
2. What does it mean to treat a charged sphere as a point charge?
To treat a charged sphere as a point charge means to simplify the physical object into a single point with all of its charge concentrated at that point. This is a simplification used in certain calculations and models.
3. When can a charged sphere be treated as a point charge?
A charged sphere can be treated as a point charge when the distance from the point of interest to the surface of the sphere is much larger than the radius of the sphere. This is known as the "far-field" approximation and is used to simplify calculations.
4. What are the limitations of treating a charged sphere as a point charge?
Treating a charged sphere as a point charge is a simplification and may not accurately represent the behavior of the actual physical object. This approximation is most accurate for objects with a uniform charge distribution and when the distance from the point of interest is significantly larger than the size of the sphere.
5. How does treating a charged sphere as a point charge affect electric field calculations?
Treating a charged sphere as a point charge simplifies electric field calculations by reducing the complexity of the system. However, this simplification may lead to less accurate results, particularly for objects with non-uniform charge distributions or when the distance from the point of interest is not significantly larger than the size of the sphere.
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
