I When can I commute the 4-gradient and the "space-time" integral?
tannhaus
TL;DR Summary
I do not know how to procceed in a situation where I have a 4-gradient and a space-time integral.
Let's say I have the following situation
$$I = \dfrac{\partial}{\partial x^{\alpha}}\int e^{k_{\mu}x^{\mu}} \;d^4k$$
Would I be able to commute the integral and the partial derivative? If so, why is that? In the same line of thought, in the situation I'm able to commute, would the result of this be
$$I = \int k_{\alpha}e^{k_{\mu}x^{\mu}}\;d^4k$$
Thanks in advance!
Since:$$e^{k_{\mu}x^{\mu}}=e^{k_{0}x^{0}}e^{k_{1}x^{1}}e^{k_{2}x^{2}}e^{k_{3}x^{3}}$$you only need to consider the behavior of a single integral of the form ##\int e^{kx}dk##. So compare:$$\frac{d}{dx}\left\{ \int e^{kx}dk\right\} =\frac{d}{dx}\left\{ \frac{e^{kx}}{x}\right\} =\frac{e^{kx}\left(kx-1\right)}{x^{2}}$$to:$$\int\left\{ \frac{d}{dx}\left(e^{kx}\right)\right\} dk=\int\left\{ ke^{kx}\right\} dk=\frac{e^{kx}\left(kx-1\right)}{x^{2}}$$These are equal so it's clearly OK to commute differentiation and integration in your situation.
Hello! There is a simple line in the textbook. If ##S## is a manifold, an injectively immersed submanifold ##M## of ##S## is embedded if and only if ##M## is locally closed in ##S##. Recall the definition. M is locally closed if for each point ##x\in M## there open ##U\subset S## such that ##M\cap U## is closed in ##U##. Embedding to injective immesion is simple. The opposite direction is hard. Suppose I have ##N## as source manifold and ##f:N\rightarrow S## is the injective...
