When do classical mechanics and electromagnetics stop working?
In summary, classical mechanics and electromagnetics cease to be effective in explaining physical phenomena at the extremes of scale and speed. Classical mechanics breaks down at the quantum level, where the behavior of particles is governed by quantum mechanics, and at relativistic speeds, where special relativity must be applied. Similarly, classical electromagnetism fails to account for phenomena occurring in strong gravitational fields or at very high frequencies, where quantum electrodynamics becomes necessary. In these cases, more advanced theories are required to accurately describe the underlying physics.
jmheer
I've heard that classical mechanics and electromagnetics are not applicable at small sizes in particle physics.
1) At what size and energy levels are they no longer considered to be applicable at all?
2) What range of size and energy levels could be considered a "transition" area where both classical and quantum are applicable to some degree?
3) What determines the "cut-off" between areas of applicability?
Thanks!
-Joe Heer
What have you found in your reading so far?
Certainly classical models do not work for electron orbitals in atoms, correct? Can you say why not?
jmheer said:
I've heard
Where? Can you give any specific references?
There’s no cut-off. There are phenomena such as the beam splitting demonstrated by the Stern-Gerlach experiment or the stability of atoms which are predicted by quantum mechanics and inexplicable by classical mechanics - naturally we apply QM to these.
Large collections of atoms (cannonballs and clouds and people and just about everything else that we encounter in our daily lives) do not usually exhibit such behavior so we apply classical mechanics to these - not because QM isn’t applicable but because the math is way easier.
Likes jmheer and Vanadium 50
As I understand it, the classical Rutherford & Bohr models where electrons are treated as point particles orbiting a nucleus do not work because the electrons would undergo centripetal acceleration to stay in orbit, and accelerating point charges radiate (Larmor equation). So the electrons would lose energy and quickly spiral into the nucleus.
Likes berkeman
So if I understand what you are saying:
1) Quantum mechanics always applies, at all size and energy scales, but is not used for larger scales because of the complexity of the math.
2) Classical mechanics, which has much easier math, is not used for certain classes of problems because the classical methods that we have don't work for those classes of problems.
Most often it is not the size scale (quantum mechanical effects can affect observations at interstellar distances, as in the Hanbury-Brown-Twiss effect) but rather the number of particles involved. It's difficult to keep a large number of particles in the coherent superposition required to demonstrate quantum mechanical effects so we seldom find objects composed of a large number of particles behaving non-classically. There are exceptions, such as superfluidity and superconductivity, but it requires extraordinary efforts to get the system into a state where these appear.
tl;dr: Stop looking for a "cutoff", instead understand for each problem whether neglecting quantum mechanical effects is an acceptable approximation.
Likes dextercioby, jmheer and gentzen
For point particles classical mechanics and electromagnetics do not consistently work already at the one-particle level. There is no self-consistent description of the accelerated motion of a classical point charge, because the radiation-reaction problem has not been fully solved after more than a century of effort. The best one can do is to use the Landau-Lifshitz approximation of the Lorentz-Abraham-Dirac Equation. This is a result in first-order perturbation theory for the radiation reaction.
The problem is satisfactorily solved by the renormalization of QED, valid to all orders in perturbation theory.
There is no fundamental transition in dependence of the size of systems known. There are macroscopic quantum phenomena for macroscopic objects like superconductivity or suprafluidity, where the collective behavior of a many-body system must be described quantum-theoretically.
Likes fresh_42
`Quantum effects become significant when you can make measurements precisely enough that Δx Δp ~ ℏ , or ΔE Δt ~ ℏ , where the uncertainties are defined based on the precision of your measurement. Somewhat relatedly, quantum effects show up when the dynamics of the system (such as its oscillation frequency) are so sensitive to the motion that you can easily observe a change in the system's energy on the order ΔE ~ ℏω , where ω is the classical (angular) frequency. The same applies when you can easily observe a change in the system's momentum on the order Δp ~ ℏk with k being a wavenumber relevant to the system (or the equivalent lattice vector, in the case of diffraction from a crystal).
FAQ: When do classical mechanics and electromagnetics stop working?
When do classical mechanics stop working?
Classical mechanics stop working accurately when dealing with objects moving at speeds close to the speed of light, or when dealing with very small scales such as atomic and subatomic particles. In these cases, relativistic mechanics and quantum mechanics, respectively, provide more accurate descriptions.
When do electromagnetics stop working?
Classical electromagnetics, described by Maxwell's equations, stop being accurate when dealing with quantum-scale phenomena, such as the interactions of individual photons with atoms. Quantum electrodynamics (QED) is required to accurately describe these interactions.
Why can't classical mechanics describe atomic and subatomic particles?
Classical mechanics cannot describe atomic and subatomic particles because it does not account for the wave-particle duality and the uncertainty principle inherent in quantum mechanics. At these small scales, particles exhibit behaviors that are best described by quantum mechanics.
What replaces classical mechanics at very high speeds?
At very high speeds, approaching the speed of light, classical mechanics is replaced by relativistic mechanics, as described by Einstein's theory of special relativity. This theory accounts for the effects of time dilation, length contraction, and the increase of mass with velocity.
How do classical electromagnetics and quantum electrodynamics differ?
Classical electromagnetics, governed by Maxwell's equations, describe the behavior of electric and magnetic fields in continuous media. Quantum electrodynamics (QED), on the other hand, describes the interactions of charged particles and the quantized electromagnetic field, accounting for phenomena such as the creation and annihilation of photons.
