When does a sound echo not disturb its listener
  • Thread starter randomgamernerd
  • Tags
    Echo Sound
In summary, the method can be used to estimate the speed of sound even if the wall is not at a known distance.
randomgamernerd
139
:[/B]
At a prayer meeting the disciples sing JAI RAM .The sound amplified by a loudspeaker comes back after reflection from a building at a distance of 80 m from the meeting. What maximum time interval can be kept between one JAI-RAM and the next JAI-RAM so that the echo does not disturb a listener sitting in the meeting. Speed of sound in air is 320 m s-1.
: [/B]s/t =v
I did a blind guess and worked out the problem as follows:
Time taken to go to the wall = Time taken to come back = 80/320 s
⇒ Time difference = 2 x 80/320 = 1/2s.
Answer matches with the one given in the text.
I just want to know significance of the line "echo does not disturb a listener"
randomgamernerd said:
:[/B]
: [/B]s/t =v
With that time difference, the echo will be heard at exactly the same time as the next JAI-RAM, so the listener may well be unaware of the echo at all - and thus "the echo does not disturb the listener".
oh, ok...thanks..
oh , ok...thanks..
A similar method can be used to estimate the speed of sound.
If you were to clap while standing 80m from a wall, the echo would return in approximately 0.5 seconds.
You can improve the accuracy of your timing, by clapping in rhythm with the echo (which you will find hard to hear when you clap exactly in time with it, but it is easy to hear of the echo arrives a tiny bit early / late, so you acn adjust your rate of clapping until it is just right).
While clapping in time, you have someone else time, say, 20 claps - and they might get a time of 9.85 seconds - showing that it was a tiny bit less than 0.5 seconds for a single sound to travel there and back.
You are thus in a position to make quite a reasonable calculation of the speed of sound, on that day, at that air temperature and that air pressure.
It wouldn't matter, to the method, if the wall was actually 77.45m away - it just makes the arithmetic a little more complicated.
whoa...thAnks for enlightening me.
Related to When does a sound echo not disturb its listener
1. When does a sound echo not disturb its listener?
A sound echo does not disturb its listener when the time interval between the original sound and the echo is greater than 0.1 seconds.
2. How does the distance between the sound source and the listener affect the disturbance caused by an echo?
The distance between the sound source and the listener does not have a significant effect on the disturbance caused by an echo. The main factor is the time interval between the original sound and the echo.
3. Can the listener's position in relation to the sound source and reflecting surface affect the disturbance caused by an echo?
Yes, the listener's position in relation to the sound source and reflecting surface can affect the disturbance caused by an echo. If the listener is directly in line with the sound source and reflecting surface, they may experience a stronger echo compared to if they were off to the side.
4. Are certain materials or surfaces more prone to causing a disruptive echo for the listener?
Yes, certain materials and surfaces can create a more disruptive echo for the listener. Smooth, hard surfaces like concrete, glass, and metal tend to reflect sound waves more strongly, resulting in a stronger echo.
5. Can adjusting the volume or frequency of the sound affect the disturbance caused by an echo?
Adjusting the volume or frequency of the sound can affect the disturbance caused by an echo. Lower frequencies tend to create a longer echo, while higher frequencies may be absorbed more quickly, resulting in a weaker echo. Lowering the volume can also reduce the intensity of the echo.
