When does infinitesimal notation break down?
In summary, the conversation discusses the use of infinitesimal notation in physics and mathematics, specifically the criticism towards Leibniz's notation and its limitations. It is noted that the notation may break down in certain scenarios, such as when dealing with curves with a tangent parallel to the y-axis or functions of multiple variables where the order of differentiation matters. However, it is also acknowledged that the use of dy/dx as a fraction in separating variables can be seen as a shortcut for applying the chain rule.
jaydnul
558
Everything I've encountered in physics so far allows infinitesimal numbers to be manipulated as real numbers. But there has been much criticism towards Leibniz's notation, and I assume it is for a reason. When in mathematics will the infinitesimal notation not work? Including treating [itex]\frac{dy}{dx}[/itex] as a fraction to solve differential equations and such. Does it ever breakdown? If so, are those purely mathematical, scholarly problems, or is there places where the notation won't work in physics?
It breaks down if you have curves with a tangent parallel to the y-axis, for example.
And there are functions of multiple variables where the order of differentiation matters.
I don't think I ever had that problem with physics-related equations.
When you use dy/dx as a fraction in separating variables, you are not really doing fraction arithmetic. You are using the chain rule, and the separation of dy and dx is a shortcut way of writing that. To see that, let's consider the example dy/dx = y. Using separation of variables you would write dy/y= dx. Then you integrate both sides, the left with respect to y and the right with respect to x (also a rather suspicious maneuver) and you get log y = x + c or [tex]y = Ae^x[/tex] where A is some constant. This is a handy way to get the right answer, but here is what you are really doing:
Let y = f(x). Your equation dy/dx = y can be rewritten in this notation as f'(x) = f(x). This gives us f'(x)/f(x) = 1. Integrating boths sides with respect to x (a clearly legitimate maneuver) we get
log f(x) = x + c
log y = x + c and so
[tex]y = Ae^x [/tex]
The chain rule comes in when you observe that [tex]\frac{d}{dx}logf(x) = f'(x)/f(x))[/tex].
So the general answer about when you can split dy and dx and treat dy/dx as a fraction is that it is justified when it is a shortcut way to use the chain rule.
Likes 1 person
Wow great point. That really helps alot
Related to When does infinitesimal notation break down?
1. What is infinitesimal notation?
Infinitesimal notation is a mathematical concept used to describe quantities that are infinitely small, or approaching zero, in size.
2. When does infinitesimal notation break down?
Infinitesimal notation breaks down when dealing with quantities that are too small to be accurately measured or calculated. This typically occurs when dealing with extremely small numbers or in cases where there is a significant margin of error in the measurement or calculation.
3. How is infinitesimal notation used in science?
Infinitesimal notation is used in various scientific fields, such as physics and calculus, to describe and analyze continuous changes and quantities that are too small to be measured directly.
4. What are the limitations of infinitesimal notation?
The main limitation of infinitesimal notation is its inability to accurately represent quantities that are truly infinitesimal, as they cannot be measured or calculated with complete precision. Additionally, it may not be applicable in certain situations where discontinuities or sudden changes occur.
5. Are there alternative notations for dealing with infinitesimal quantities?
Yes, there are alternative notations, such as limit notation, that can also be used to describe and analyze infinitesimal quantities. However, each notation has its own limitations and is used in specific contexts depending on the nature of the problem being solved.
  • Calculus
