MHB When Does the Norm of the Sum Equal the Sum of Norms for Integral Operators?
  • Thread starter Thread starter sarrah1
    Norm Sum
sarrah1
Hi
I have 2 linear integral operators
$(Ku)(x)=\int_{a}^{b} \,k(x,t)u(t)dt$
$(Mu)(x)=\int_{a}^{b} \,m(x,t)u(t)dt$
I am defining $||K||=max([x\in[a,b]\int_{a}^{b} \,|k(x,t| dt$ same for $L$
when does $||K+M||=||K||+||M||$
thanks
sarrah
sarrah said:
Hi
thanks
sarrah
I believe that the answer will be "hardly ever". Notice that $\int_{a}^{b}|k(x,t)|\, dt$ and $\int_{a}^{b}|m(x,t)| \,dt$ are both functions (of $x$), and the sup norm of a sum of two functions is very seldom equal to the sum of the sup norms of the functions. In fact, equality only occurs if the two functions attain their maximum at the same point.
Dear Oplag
you are always of great help.
But if a,,b greater than 0 and both k(x,t) and m(x,t) are represented by series of positive terms only or negative terms only, like $k(x,t)=sinhxt$ and $m(x,t)=xt+x^3t^3/3!$ i.e. $m(x,t)$ and $k(x,t)$ reach their maximum at point b then $||M||+||K-M||=||K||. right ?
- - - Updated - - -
Dear Oplag
But if a,b greater than 0 and both k(x,t) and m(x,t) are represented by series of positive terms only or negative terms only, like k(x,t)=sinhxt and m(x,t)=xt+x 3 t 3 /3! i.e. m(x,t) and k(x,t) reach their maximum at point b then $||M||+||K-M||=||K||. right ?
That is correct. In that case, the functions both attain their maximum at the endpoint $b$, so that is the exceptional situation when the norm of the sum is the sum of the norms.
Dear Oplag
final 2 small questions and I wouldn't bother you anymore:
1. When I write $||K||=max ( x\in[a,b])\int_{a}^{b} \,|k(x,t)| dt$ should I write $||K||\infty$ on the L.H.S instead of $||K||$ only
2. For 2 linear integral operators $K$ and $M$ say is $||K+M||\le||K||+||M||$ ? always
thanks
sarrah
sarrah said:
1. When I write $||K||=\max ( x\in[a,b])\int_{a}^{b}|k(x,t)|\, dt$ should I write $||K||_\infty$ on the L.H.S instead of $||K||$ only
Personally, I would not put a subscript $\infty$ against that norm. That subscript usually indicates a supremum norm, which in this case would mean the norm $$\|K\|_\infty = \max_{x,t\in[a,b]}|k(x,t)|.$$ But the norm here is a "mixed norm", obtained by using the sup norm for the $x$ variable and the $L^1$-norm (the integral norm) for the $t$ variable.
It is part of the definition of a norm that it should satisfy the triangle inequality $\|A+B\| \leqslant \|A\|+\|B\|$. That certainly applies in the case of this integral norm.
I posted this question on math-stackexchange but apparently I asked something stupid and I was downvoted. I still don't have an answer to my question so I hope someone in here can help me or at least explain me why I am asking something stupid. I started studying Complex Analysis and came upon the following theorem which is a direct consequence of the Cauchy-Goursat theorem: Let ##f:D\to\mathbb{C}## be an anlytic function over a simply connected region ##D##. If ##a## and ##z## are part of...
