When i incubate my mammalian cells
  • Thread starter sotellme
  • Tags
    Cells
In summary, the lid should be fully placed on the multiwells and petri dishes to avoid evaporation and potential edge effects. For culture flasks, the lid should be loosely twisted to allow for air circulation but not loose enough to fall off during transport. This is less of an issue for evaporative loss as the cells are usually grown for later use and not directly sampled from the flask.
sotellme
75
how should the lid be when i incubate my cells in:
1. multiwells: should i tilt the lid so that half of the plate is covered and half is exposed directly to air in the incubator? or should i just have the lid on so the whole plate is covered?
2. culture flask: should the lid be loosened (contamination risk)? or should i tie it completely (my cells can not get air )?
3. dish: should i only cover half of the dish? in this way half is covered and half is exposed directly to air in the incubator? or should i just have the lid on so the whole dish is covered?
thank you.
Biology news on Phys.org
For the multiwells, place the lid fully on the plate, the same goes for petri dishes. There will be too much evaporation with the lid skewed. Even with the lid on there will be plenty of air circulation, especially in the wells around the periphery of the plate. I have run across certain endpoints that are sensitive to this and an "edge effect" can be found if that data is examined correctly. I know certain labs that use 48-well formats and fill all the outer wells with PBS to eliminate such effects, I also use this technique for culturing of fetal thymus on porous membrane inserts, these can dry out very rapidly since the tissue is kept at the air-medium interface and keeping them in the outer wells is bad news.
When using culture flasks, or T-flasks, twist the cap so it is loose, but not so that it will potentially fall of when transporting the flasks (I usually tighten then caps before puling the flasks from the incubator anyway, but other people may bump them loose in a crowded incubator). Evaporative loss is less of an issue in this situation since there is less "exposure" to the incubator air and typically you're growing cells for later plating and not collecting samples directly from these flasks.
1. For multiwells, it is best to have the lid on so that the whole plate is covered. This will ensure that the cells are protected from any potential contaminants in the air and maintain a stable environment for growth. Tilting the lid may expose the cells to uneven temperature and humidity, which can affect their growth and viability.
2. For culture flasks, it is important to have the lid securely tightened to prevent any contamination. However, it is also necessary to have a small vent or filter on the lid to allow for gas exchange and prevent a build-up of carbon dioxide. This can be achieved by using a specialized flask cap or loosening the lid slightly to allow for a small opening.
3. Similarly, for dishes, it is best to have the lid on so that the whole dish is covered. This will provide a stable environment for the cells to grow and prevent any contamination. Exposing half of the dish to air may also result in uneven growth and potentially affect the experimental results.
In summary, it is important to have the lid securely on for all types of cell culture vessels to prevent contamination and maintain a stable environment for cell growth. However, it is also necessary to have a small vent or filter to allow for gas exchange and prevent a build-up of carbon dioxide. If using a specialized vessel with a vent or filter, follow the manufacturer's instructions for proper usage.
FAQ: When i incubate my mammalian cells
What is the purpose of incubating mammalian cells?
The purpose of incubating mammalian cells is to provide a controlled environment for the cells to grow and divide. This allows researchers to study the cells and observe their behavior under specific conditions.
What temperature should I incubate my mammalian cells at?
The optimal temperature for incubating mammalian cells is typically between 37°C and 39°C, which is equivalent to body temperature. However, this may vary depending on the specific type of cell being incubated.
How long should I incubate my mammalian cells for?
The length of time for incubating mammalian cells will depend on the specific experiment or purpose. Generally, cells are incubated for 24-48 hours, but some experiments may require longer or shorter incubation periods.
Do I need to add any supplements or media to the cells during incubation?
Yes, it is important to add appropriate growth media and supplements to the cells during incubation. This provides the necessary nutrients and environment for the cells to thrive and grow. The specific media and supplements needed will depend on the type of cells being incubated.
How often should I change the media during incubation?
The frequency of media changes during incubation will depend on the specific needs of the cells and the experiment being conducted. Typically, media is changed every 2-3 days, but some experiments may require more frequent changes. It is important to monitor the cells and media carefully to ensure they are healthy and growing properly.
