When is an element of a finitely generated field extension algebraic?
In summary, Hungerford explains that in the field extension K \subset K(x_{1},...,x_{n}), each x_{i} is transcendental over K. This means that every element of K(x_{1},...,x_{n}) that is not in K itself is also transcendental over K. However, this does not necessarily hold true for simple extensions, where the primitive element may be algebraic over the field. The x_{i}'s in Hungerford's explanation are indeterminates, which are by definition transcendental over K. When considering a specific example, such as K = ℝ and K(x_{1}) = ℝ(i) = ℂ, we must remember that "i" is not an ind
TopCat
58
Hungerford says that
In the field extension
[tex]K \subset K(x_{1},...,x_{n})[/tex]
each [itex]x_{i}[/itex] is easily seen to be transcendental over K. In fact, every element of [itex]K(x_{1},...,x_{n})[/itex] not in K itself is transcendental over K.
But if we take K = ℝ and [itex]K(x_{1})[/itex] = ℝ(i) = ℂ, we have that i is not in ℝ yet is algebraic over ℝ. Guess I'm missing something here. Is it that this need not be true for simple extensions if the primitive element is algebraic over the field?
Hungerford's x_i's are supposed to be indeterminates, i.e. they're transcendental over K by definition (essentially).
When you write down "i" you're implicitly thinking of a complex number that satisfies the polynomial x^2+1 - i.e., you're not thinking of an indeterminate.
FAQ: When is an element of a finitely generated field extension algebraic?
What is a finitely generated field extension?
A finitely generated field extension is a field that is obtained by adjoining a finite number of elements to a base field. This means that every element in the field can be expressed as a finite combination of the base field and the added elements.
What does it mean for an element to be algebraic in a finitely generated field extension?
An element is algebraic in a finitely generated field extension if it satisfies a polynomial equation with coefficients in the base field. This means that the element can be expressed as a root of a polynomial with coefficients from the base field.
How is the concept of algebraicity related to field extensions?
In the context of field extensions, algebraicity refers to the property of an element being able to be expressed as a root of a polynomial with coefficients from the base field. This is important in understanding the structure and properties of field extensions.
What are the implications of an element being algebraic in a finitely generated field extension?
If an element is algebraic in a finitely generated field extension, it means that it is a member of a smaller subfield of the extension. This has implications for the structure and properties of the field extension, such as its degree and the existence of a basis.
How can we determine if an element is algebraic in a finitely generated field extension?
An element is algebraic in a finitely generated field extension if and only if it satisfies a polynomial equation with coefficients in the base field. This means that we can determine algebraicity by checking if the element satisfies a polynomial equation with coefficients from the base field.
