When is Multiplying or Composing Functions Useful?
  • Thread starter armandshamar
  • Tags
    Functions
In summary, the product rule states that you take the product of the functions and then differentiate.
armandshamar
I know this sounds like a strange, maybe impossibly naive question, but I have a B.S. in Math and have done some graduate work and I find myself teaching the chain rule and product rule to undergrads. I can get some intuition on why the rules work the way they do, but I find I can't think of any good simple concrete examples of why we would have functions for things and then multiply or compose those functions. What are some nice examples of this?
Suppose you have some machinery in which there are rotating components, like gears or cams. Maybe like a drivetrain in a car. To find the torque on a component, you want to multiply force by axial distance. But both of these change as your component rotates through its cycle, and so are dependent on the angle. So to find the torque at any time, you multiply one function of angle (force) by another function of angle (axial distance).
Now think about the engine in the car. The fuel efficiency of the car depends on the efficiency of the engine, and the engine efficiency depends on the temperature. So the fuel efficiency is a function of the engine efficiency, which is a function of the temperature.
These concepts are extremely general, and I can literally think of thousands of other examples. Whenever you multiply two values, ask yourself whether these values depend on any variables. If so, you are multiplying two functions together. Whenever you have one function, ask if the variables themselves depend on other variables. If so, you have a function of a function.
I hope this helped; ask if you still have questions.
The most common use of "composition" is to break complicated functions into simpler functions. For example, [itex]\sqrt{1- x^2}[/itex] can be thought of as the compostion of [itex]f(x)= \sqrt{x}[/itex] and [itex]g(x)= 1- x^2[/itex].
The classical damped (decaying) harmonic oscillator in physics has solutions of the form
[tex]x(t) = e^{-\alpha t} \left( A \sin(\omega t) + B \cos(\omega t) \right) [/tex]
If you want to get the velocity and acceleration, you'll need to use the product rule when you differentiate.
FAQ: When is Multiplying or Composing Functions Useful?
When is multiplying functions useful?
Multiplying functions is useful when you need to combine two or more mathematical operations, such as addition, subtraction, and division, in a single function. It is commonly used in physics and engineering to model systems with multiple inputs and outputs.
When is composing functions useful?
Composing functions is useful when you need to apply two or more functions in a specific order. It allows you to break down complex problems into smaller, more manageable steps. It is commonly used in calculus and statistics to solve equations and analyze data.
What is the difference between multiplying and composing functions?
The main difference between multiplying and composing functions is the order in which the operations are performed. When multiplying functions, the operations are performed simultaneously, while composing functions involves performing one function on the output of another function.
What are some real-life examples of using multiplying or composing functions?
Multiplying functions can be used to model compound interest in finance, where the interest earned each period is added to the initial amount and then multiplied by the interest rate. Composing functions can be used to analyze the effects of medication on the human body, where the dosage of the medication is applied to the body's response function.
How can I determine when to use multiplying or composing functions in a problem?
The decision to use multiplying or composing functions depends on the specific problem at hand. Generally, if the problem involves multiple operations, such as addition, subtraction, or division, multiplying functions would be more appropriate. If the problem involves a sequence of operations, such as applying a function to the output of another function, composing functions would be more suitable.
