When Is \( n^4 + 4 \) a Prime Number?
  • MHB
  • Thread starter Greg
In summary, prime numbers are positive integers that can only be divided evenly by 1 and itself. To determine if a number is prime, you can use the Sieve of Eratosthenes method. The significance of n^4+4 in this problem is that it is a prime-generating polynomial, which means that when you plug in different values for n, you will get a prime number as the result. To solve for n in n^4+4, you can use algebraic methods such as factoring or the quadratic formula. This problem is important in mathematics because it showcases the beauty and complexity of prime numbers, the power of algebraic methods, and the many real-world applications of prime numbers.
Greg
MHB
1,378
Here is this week's POTW:
Given that $n$ is an integer greater than $0$, when is $n^4+4$ prime?
Remember to read the https://mathhelpboards.com/showthread.php?772-Problem-of-the-Week-%28POTW%29-Procedure-and-Guidelines to find out how to https://mathhelpboards.com/forms.php?do=form&fid=2!
Congratulations to Opalg, topsquark, kaliprasad, Olinguito and castor28 for their correct solutions. castor28's solution may be found below.
We have the polynomial identity:
n^4 + 4 = (n^2 - 2n + 2)(n^2 + 2n + 2)
Where both factors are integers if $n$ is an integer. The second factor is always greater than $1$, and the first one is greater than $1$ if $n>1$, in which case $n^4+4$ is composite. If $n=1$, $n^4+4=5$ is prime.
Therefore, $n^4+4$ is prime if and only if $n=1$.
FAQ: When Is \( n^4 + 4 \) a Prime Number?
What are prime numbers?
Prime numbers are positive integers that can only be divided evenly by 1 and itself. In other words, they have no other factors besides 1 and itself.
How do you determine if a number is prime?
To determine if a number is prime, you can use the Sieve of Eratosthenes method. This involves creating a list of numbers from 2 to the number you want to check, and then crossing off all the multiples of each number. If the number is not crossed off, it is prime.
What is the significance of n^4+4 in this problem?
In this problem, n^4+4 is known as a prime-generating polynomial. This means that when you plug in different values for n, you will get a prime number as the result. This is a rare occurrence and has been studied by mathematicians for centuries.
How do you solve for n in n^4+4?
To solve for n in n^4+4, you can use algebraic methods such as factoring or the quadratic formula. In this particular problem, the answer is n=1, as 1^4+4=5, which is a prime number.
Why is this problem important in mathematics?
This problem is important in mathematics because it highlights the beauty and complexity of prime numbers. It also showcases the power of algebraic methods in solving mathematical problems. Additionally, prime numbers have many real-world applications, such as in cryptography and computer science.
