When is the average speed equal to the average of the speeds?
In summary: Also, a question was posed about the case where there are more than two speeds involved. I think the OP is trying to relate this to the definition of average speed rather than average velocity.In summary, the question is asking under what conditions the average speed is equal to the average of the speeds. The equation for average speed is (Xf-Xo)/(tf-to), while the equation for average of the speeds is (vf+vo)/2. It is only when there is a constant acceleration that these two equations would be equal. This means there would be a constant change in velocity over time, resulting in a straight line on a velocity-time graph. If there are more than two speeds involved, the equations for average speed and
Gjmdp
148
In which conditions the average speed equals the Average of the Speeds?
Average speed= (Xf-Xo)/(tf-to)
Average of the speeds= (vf+vo)/2
I tried to set up a formula for vf and vo, but it would be false to determine that
vf=xf/tf, because if vf=0, xf=2 and tf=1 ->vf=2/1 which is not 0. I tried also to set
vx=a*t + vo, but I'm getting nowhere. Please help :)
I know that it is the case when there is no acceleration. But I'm trying to figure if there is other cases.
Is this going to be for the case of 2 different speeds, or a more general case?
Suppose it's at 2 steady speeds, and there is no acceleration (apart from one abrupt change to a new speed partway through the journey).
So you travel at a speed of v1 for some of the trip, at at a speed of v2 for the remainder.
►► What is an expression for the trip's average speed, in terms of those speeds?
suggests to me we are to take the average of all of the set of speeds, might be more than two. But suppose it is just two, v1 and v2. Let the times at those speeds be t1 and t2. What equations can you write relating to average speeds?
Average speed= (Xf-Xo)/(tf-to) is general expression which is valid for both (constant as well as non constant acceleration). Whereas Average of the speeds= (vf+vo)/2 would only be equal when the graph between velocity and time would be a straight line (or alternatively when there would be a constant acceleration). As can be seen from the equation of Average of the speeds that it is the equation of finding the mid point of line segment.
Conclusion:
The only time Average speed= (Xf-Xo)/(tf-to) and Average of the speeds= (vf+vo)/2 would be equal when there is a constant acceleration.
I see you have chosen to interpret this problem differently to how I believe was likely intended. Do you understand what I wrote in post #2 in this thread?
Inamulhaq said:
Average speed= (Xf-Xo)/(tf-to) is general expression ...
This expression is for the average velocity, not the average speed. Average speed is equal to total distance covered (as in recorded by a car's odometer) divided by the time interval it takes to cover that distance.
Gjmdp did not define Xf and X0.
It doesn't sound from the question as though we are to consider an infinity of speeds, which rules out any smooth accelerations. As Nascent wrote, it would be a finite set of constant speeds.
Besides, there are many ways in which the two averages could happen to be the same.
I agree, but the numerator should be the absolute value of the difference otherwise it admits the possibility of a negative ratio which cannot be a speed.
FAQ: When is the average speed equal to the average of the speeds?
1. When is the average speed equal to the average of the speeds?
The average speed is equal to the average of the speeds when the distance traveled and the time taken are both the same for each speed. This means that the total distance divided by the total time will result in the same value for all the speeds being averaged.
2. How is average speed calculated?
Average speed is calculated by dividing the total distance traveled by the total time taken. This gives the average amount of distance traveled per unit of time.
3. Is average speed the same as constant speed?
No, average speed and constant speed are not the same. Average speed is calculated based on the total distance and time, while constant speed refers to a speed that remains the same throughout the entire duration of travel.
4. Can the average speed be higher or lower than the fastest or slowest speed?
Yes, the average speed can be higher or lower than the fastest or slowest speed. The average speed is calculated by taking into account all the speeds and their corresponding distances and times, whereas the fastest and slowest speeds only consider one specific speed.
5. How does the average speed affect the overall travel time?
The average speed can affect the overall travel time by either decreasing or increasing it. A higher average speed will result in a shorter travel time, while a lower average speed will lead to a longer travel time. This is because the average speed is directly influenced by the total distance and time, and can affect the overall duration of the trip.
