Simfish
- 2
It's really a finely divided line, and varies with professor to professor, subject to subject, and friendliness to friendliness.
There's the often-mentioned 30-minute rule, where if you're stuck for 30 minutes, you should go up to the professor and ask for a pointer (which is usually not sufficient in itself to solve the problem for you). But sometimes, this rule will make you ask questions about all your homework problems, which could annoy your professor.
The one thing is that if they give you a pointer, you might get enough information to solve the problem. Or you might not. If you still don't have enough information to solve the problem, you can try and go up to the professor again. In which case you might start annoying the professor. Or you might not.
On the other hand, you could just do your own version of the solution (which may contain some things you made up - making things up can sometimes guide you to the real answer), and then come to the professor and ask, "Am I doing things right?" They might look at you silly and think "what are you doing?" Or they might alternatively think that you're asking for the solutions. Or they might actually be responsive.
