When should i apply energy conservation?
In summary, the conversation discusses a setup where two balls of mass 60g are attached to a massless rubber thread and held in a vertical position. The upper ball is slowly raised until the lower ball is no longer supported by the ground. The question is asked about the force constant of the rubber thread, and two attempts are made to calculate it using the work-energy theorem and Newton's equations. However, the correct approach is to calculate the work performed by all the forces on the ball and set it equal to the change in kinetic energy. The key piece of information needed to solve the problem is that the lower ball becomes unsupported by the ground.
Aditya Tarey
[Two ball of mass 60g are attached with mass less rubber thread and held in vertical position as show in figure.
In this position length of rubber thread is 40cm and it is not stretched. The upper sphere is slowly raised vertically upward until the lower ball just becomes unsupported by ground. At this time length of thread is 1m. The rubber thread exerts a force which is proportional to its extension.
Q. What is force constant of rubber thread ? Ans 1N/mAttempt 1
On Applying work energy theorem
x = 60 cm
Mgx = 1/2kx^2
K= 2N/m
Attempt 2
x = 60 cm
On Applying Newtons Equatns
Mg = kx
k = 1N/m
Doubt: Why is first Attempt wrong.
Because energy is not conserved. While you raise the ball you exert force on it, which means you are giving the system energy. Unless you calculate that energy, it won't work. The
Conservation of energy is NOT just the potential energies of the ball and the spring! There is also the speed the ball gains and the energy you use to stop that speed in the end.
Then wouldn't you need to know that final=initial speed? Since if the ball's speed changes at all from it's initial vertical position it will have Gained energy.
So if ball is not raised slowly and there is some non zero vertical velocity we can not apply energy conservation.
You can always apply conservation of energy if you can account for where all the work goes. That's not the same as saying whether that approach would be fruitful, however. In this case, it wouldn't tell you anything useful.
In your attempt, you didn't apply the principle correctly which is why you got the wrong answer. You have to calculate the work performed by all forces on the ball and set that equal to the change in kinetic energy. When you lift the ball, you have the upward applied force, gravity, and the spring all acting on the ball. If you do it correctly, you'll end up with 0=0 or find you don't have the correct information to solve the problem.
The key piece of information is that "the lower ball just becomes unsupported by ground." That's not easily interpreted in terms of energy, but it's straightforward to comprehend in terms of forces. That's why the force approach is the way to go for this problem.
Vela , wow! I could never say it ins such a clear way (but then again I'm 18 and still have a lot to learn!)
FAQ: When should i apply energy conservation?
When is the best time to start implementing energy conservation practices?
The best time to start implementing energy conservation practices is as soon as possible. The longer you wait, the more energy and money you will waste. It is never too early or too late to begin conserving energy.
How can energy conservation benefit me and my household?
Energy conservation can benefit you and your household in many ways. It can help reduce your energy bills, lessen your carbon footprint, and contribute to a healthier environment. Additionally, energy-efficient homes are more comfortable and have better indoor air quality.
What are some practical ways to apply energy conservation in my daily life?
There are many simple and practical ways to apply energy conservation in your daily life. Some examples include turning off lights and electronics when not in use, using energy-efficient appliances, adjusting your thermostat, and choosing renewable energy sources.
Is energy conservation only important for households, or does it have a larger impact?
Energy conservation is important for both households and the larger community. By conserving energy, we can collectively reduce our carbon emissions and help combat climate change. It also helps preserve natural resources and protect the environment for future generations.
Can energy conservation really make a difference?
Yes, energy conservation can make a significant difference. Small actions, when done by many people, can have a big impact. By implementing energy conservation practices, we can reduce our energy consumption and decrease our carbon footprint, leading to a more sustainable future for our planet.
