When the snow started falling, the boys noticed
  • Thread starter BakyX
  • Tags
    Falling
In summary: This is because air requires a lot more heat to change it's temperature then snow does. When the snow starts to fall, the air is cooled more and the rate of heat transfer is slower. This means that the air next to your skin feels colder then the air temperature.
BakyX
When the snow started falling, the boys noticed that the air in the night and snow had the same temperature. However, snow seemed to be cooler on touch...
State the reasons in detail, why it is like that.
Hello..Can someone help me with that ? It isn't homework..
When you feel heat or cold what your body is actually feeling is the rate of heat transfer into or out of the body through the skin. Air requires a relatively small amount of heat to change it's temperature so if you stand still in still air the air right next to your body quickly warms up, this reduces the temperature difference and therefore the rate of heat transfer. If there is wind the warm air is constantly swept away and you feel colder because you are loosing heat faster. Ice or snow will absorb heat faster then air at the same temperature, since your body senses heat transfer instead of actual temperature this translates into feeling colder.
This is also why people are able to walk over hot coals. They may be over 1000 degrees F but they are very bad at transferring heat so your feet are able to absorb and despite the heat as fast as it is transferred without burning.
Thx so much..
"This is also why people are able to walk over hot coals. They may be over 1000 degrees F but they are very bad at transferring heat so your feet are able to absorb and despite the heat as fast as it is transferred without burning."
It's very interesting information. THX
Precisely... This is also why even when the surrounding air temperature might be lower than the temperature of water in a lake, you will still get hypothermia if you take a small dip rather than walk around.
Mr speedybob is right. When you touch something with your finger, you don't feel the temperature of what you touch, you feel the temperature of your finger. Air does not cool your finger down as fast or as much as snow, even tho they are both at the same temperature.
FAQ: When the snow started falling, the boys noticed
When does the snow usually start falling?
The start of snowfall can vary depending on location and weather patterns. In some areas, snow can start falling as early as October, while in others it may not start until December or even later.
How does snowfall affect the boys?
The impact of snowfall on the boys can vary depending on their individual experiences and circumstances. Some may enjoy playing in the snow, while others may find it inconvenient for transportation or outdoor activities.
Why did the boys notice when the snow started falling?
The sudden appearance of snow can be a noticeable event for anyone, especially if it is the first snowfall of the season. The boys may have also been outside or near a window when the snow started falling, making it more noticeable.
What is the significance of the boys noticing when the snow started falling?
The significance of the boys noticing the snowfall could vary depending on the context of the situation. It could be a simple observation or it could symbolize a change in the season or their surroundings.
Is there a scientific explanation for when and why snow starts falling?
Yes, snowfall is a natural phenomenon that occurs when atmospheric conditions are conducive to the formation of snowflakes. It usually happens when there is enough moisture in the air and the temperature drops below freezing.
